22re idle set
Old Apr 15, 2024 | 06:05 PM
Brokton's Avatar
22re idle set
i have a 1990 pickup that i need to set the idle on. but the service manual is a little bit vague on what needs to be done. is there a specific target temp that is trying to be achieved?
Old Apr 16, 2024 | 07:51 AM
osv's Avatar
osv
in terms of temps, are you trying to set a cold idle? what is the current idle rpm?
Old Apr 16, 2024 | 08:09 AM
Brokton's Avatar
I am talking about this idle procedure
Old Apr 16, 2024 | 08:43 AM
osv's Avatar
osv
"2,500 rpm for 2 minutes" sounds like it's intended to be an idle speed adjustment for a warm engine? i usually do that with a timing light that has tachometer capability.
Old Apr 16, 2024 | 08:49 AM
Brokton's Avatar
From what I understand their goal is to heat soak the radiator so that way when the engine is at a high operating temperature will continue to idle normally. I'm just trying to better understand what their temperature goal is for that heat soak
Old Apr 16, 2024 | 12:01 PM
osv's Avatar
osv
it would have been nice to see a temp operating range to set the idle at... i used to work on cars in below-freezing weather, had to put cardboard in front of the radiator to get the engine hot... running an engine for 2 minutes in that weather wouldn't have been enough.
AuDuryea
Jan 28, 2024 07:07 AM
blueyoda
Dec 1, 2010 05:58 AM
newjerseyredneck
Mar 18, 2005 03:35 PM
PirateFins
Mar 14, 2003 08:59 AM
