- Transmission Filter change - questions
- What do i need if....????
- 2wd or 4wd radiator difference?
- beefed up i.f.s. or sas
- Finished ISR
- hello everyone
- Is this necessary??
- Brake Light in cluster?
- 22re idles but cuts out.
- 89 door on a 92 4rnr
- Should I buy this 1988 Toyota 4x4 Truck
- Should I buy this 1988 Toyota 4x4 Truck?
- Fan exploded.
- pic of my '92 22re truck
- Towing with a Toy
- trans ratios
- SAS 3", 4" or 5" ?
- Any way of knowing if I'm at TDC?
- How to ID W55 transmission
- brake calipers
- Idiot lights come on at idle
- Noise Questions
- Cold Start Injector
- Yet another shifter removal question...
- Clutch to the floor, won't go into any gear
- Small black connector at starter
- 3.slow cuts out
- Question about SAW T-Bars
- 22r boggin' out
- afm help needed
- Background Pics!
- Idler arm weirdness--help?
- insturment cluster removal
- Needing some parts / ASAP
- 22RE Actin up any Ideas???
- Drain tranny oil before pulling engine?
- Seatbelt Exchange???
- Not your normal rough idle
- fuel filter replace 94 22-re
- vacuum hoses
- Red Interior 89 4 runner parts needed
- Lift question?
- Beautiful Front Lawn
- help with truck pulling
- Recalls
- Im beating myself up over this (Cylinder Head Issue)
- Best place to get tires?
- Holy ˟˟˟˟˟,, my truck is making a noise that I have never heard going out of 4 into 2!
- 3.0 question
- 1992 Seal trouble
- passenger side dome light button broken 2nd gen
- my lift opinion & wheel backspacing question
- SR5 Guage swap - Oil pressure sender ???
- New Bumper, should I change the style
- 340H Tranny Question
- idler arm difference?
- 4 Wheel Drive Question??
- anybody near philiadelphia PA that wouldnt mind helping me install a clutch
- sas question......
- Changed Plugs- Hot
- Aux. fuse panel, switched?
- surging idle
- Brown water comming out of exhust?
- Black Smoke- EEEEEK!
- what years for 8" rear end
- Pulling Durango out = Burnt Clutch
- Part Number look-up, Oil Gage assembly:
- My truck makes water!! Is this a good thing?
- 93 p/u front end to 4runner. side blinker dont work?
- (!)Brake, Battery, A/T Temp lights in dash.
- Combination Turn Signal and Parking Lights...w/ Budbuilt Pics!
- what do you think of my new 4-runner?
- well I need a new clutch
- Electrical Fan Wiring
- So my brakes went out on the hwy today...
- In dash drink holder for '88 pickup (and related ash tray question)
- New gears
- Differential leakage
- how LONG is a 3vze supposed to smoke after...
- 22RE exhaust port pictures
- Manual hubs always engaged..
- 94 V6 callipers on my 86 pickup
- engine wont run
- Midwest to the Northeast (snow storm)
- Wheel dust protectent
- TRDparts4u OME 3-4" lift PICS
- Hello! Newbie Owner here!!!
- Rear Window, 2ndGen to 1stGen
- timeing and sparkplug gaping?
- Check engine light only comes on at speed
- cat, muffler, pipes
- Clutch slipping like crazy
- oxygen sensor install
- 1990 4runner with no motor 4 sale
- TDC or not?
- Removing Wrist Pins
- Yota yard
- Uhual Dually
- Thanhhks a million Yotatech folks!!!
- Diesel Surfs?
- why does this get hot?
- Anti-Lock Light
- fuse box diagram
- Front E-brake cable installed, but no brake response
- 92 4runner speed sensor
- Bad rattle from front left suspension
- Is this True (Oil Question)
- Radiator Fan stopped working.
- what is this VAC TUBE...
- Make sure your brakes are working right!!
- Threw a set of 35s on my 4runner (pics)
- Finding a cheap Catalytic Converter in SoCal
- 1987 EFI Toyota Truck
- Idle Issue
- Painted faded top! pics
- Longbed pic post!
- Fuel pressure testers - What do you guys have?
- Hillbilly cruise control/hand throttle?
- low voltage under load - bad alt. vs bad ground
- funny idle
- 1990 4runner w/3.0 v6
- stereo and tach wiring
- Taurus Fan Question
- Auto to 5Speed Swap
- 92 4run questions
- technical exhaust questions
- just got a 94 t100 3vze any advice for engine/chasis mods?
- header technical help
- New R&P as well as locker change
- Bumper Woes!!
- Clutch play...
- Removing my 3" lift
- LC engineering supercharger
- Timing
- Sonoran Steel IFS brace? strength
- timing issues
- My 95 4Runner's compression
- help 7mge
- Sloppy steering
- Front lift
- 4runner door panels in a 91 truck
- Seat swap?
- help! no power to fuel pump
- EGR removal
- disappearing oil cause found, rear main seal..
- Looking to replace torsion bars
- carb adjustments?
- 5sp vs Automatic, buyers question!
- Is it possible ???
- 1995 4Runner Parts for Sale
- Converting 88 toyota pickup w/ no powersteering to powersteering
- 1994 4Runner seat question
- what do you think?
- New guy here
- air conditioner fuse
- another 3.4 swap
- 87 22R 4X4 PU Drivetrain Vibration
- Seat covers and floor carpet
- steering wheel rub
- How much for an ARB winch bumper
- Safari Rack Pros and Cons
- OIL LEVEL LOW, Please Help
- moving timing chain
- where to get seafoam in Canada???
- Too many miles for synthetic oil?
- ect fuse? Help
- 89 22RE - low compression and coolant in the oil
- 3.0 problems?
- rack
- best place to get a clutch?
- Fan Disaster Averted
- 3.4 into 92 4runner help newbie!
- Identify this winch! Rebuildable?
- 7.5" IFS interchangeability question...
- Vacuum Lines Ahoy!!! Need some help figuring what goes where.
- 3rd gen front end on a 2nd
- unkown wires
- timing ? 22rtec 1986 4x4 pick up
- What is this?
- When should I replace O2 sensor.
- Need 6 gears on 22re
- Rear driveshaft/transfer case end seal leaking?
- Drums are getting hot...
- more details on sea foam in 22r carbed engine please
- 3vze hesitation won't end! help!
- engine advice needed
- 91 Speedo cable removal?
- test drive in HD
- Is this everything in the lock rite???
- pic of pillar gauges on a 86
- new to the forum and have a few questions
- timing jumper connector?
- Egr
- Hydro Locked
- what do you think about mod???
- 3VZE maintenance suggestions
- IFS Locker Install-??'s
- FAN BRACKET! or water pump?
- 3VZE Crankshaft Timing Pulley
- rear axle seals
- 90 4Runner
- Funky running in the morning....
- identify this locker? lockright...?
- Check Engine Light On
- Help! Power Antenna Issues
- 90 4Runner, putting on a lift
- how to take off my dash?
- $300 for a sfa...?
- what is a leveling kit?
- My 1994 4x4 turbocharged 22re.
- I Need pics of how your brushbar is attached
- New to YT heres my '90 22RE pickup
- 86 runner -89 22re
- 1994 toy gotta see it
- 3.0 = most reliable engine ever?????
- blowing smoke/steam...but BHG was recently fixed...what else could it be??
- A/C Problems
- 1st gen, 2 gen ?
- Cold morning starting
- What happens to unadjusted brake shoes?
- Tranny Gear Ratios
- Spark Plug Gaps
- Light for climate control
- Stock gearing/gas mileage
- Anyone reuse thier clutch?
- Is 500$ for 4.88 axle and Diff to much?
- 89 3VZE Front Crank Seal Replacement
- New to toyota's
- Yakima or similar rack on Xtra-Cab
- '91 V6 PU Start problems... still!
- Power steering pump... question
- drain plug size?
- Confused about my idler arm
- Floatin Your Gears
- Distributor fire
- Air Silencer removal questions
- Flowmaster
- Body lift and Auto Trans
- '92 3.0 Rod or Wrist pin knock?
- Alignments
- 22re is driving me nuts
- 33x12.50x15R on a 3.0L V6 Auto
- Best gears for 33" tires?
- Power Steering Info. 22R or 22RE
- Weird shifting auto 4Runner
- Finally got my 4runner back....but a code 71....but without the symptoms??
- Who besides ARE makes these wheels?
- how to test ect button?
- Would you buy a 90 4Runner for $500?
