pic of pillar gauges on a 86
Old Feb 9, 2007 | 05:55 PM
Just Learning's Avatar
this took me a long time and was a big pain , i wouldnt do this again
Old Feb 9, 2007 | 06:08 PM
tampabayota's Avatar
i like where did you get it, i want one
Old Feb 9, 2007 | 06:12 PM
4Crawler's Avatar
Looks like Mosk's gauge pod, see:
- http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Old Feb 9, 2007 | 06:45 PM
tc's Avatar
tc
Are the pillars in the first gen the same as second gen? I need to install a new gas gauge and this would be the preferred location, but I can't find any pods for a 2nd gen...
Old Feb 9, 2007 | 07:11 PM
gauges
yes there from mosk's i believe i paid about 75, but there is very little room in the pillar to gauge holder, it would of been better if the holder came out more, and to make it off roadability ie. chaffiing of wire being able to replace lite bulbs ect go to westwood and get the proper paint, also i had to do a little trimming via heating it up to make it fit really good, it really was a pain and if you go with auto meter guages you will also need the npt to bpt adapters. anyway i do think it looks good too , now to work on floor board insulation and then put in my buckets seats and then to herculiner the truck and and...........
Old Feb 9, 2007 | 07:48 PM
Stomis's Avatar
Fuel pressure guage in-cab?! I hope thats an electronic sender because everything I ever read in my Camaro days said "NO INCAB FUEL PRESSURE"
Old Feb 9, 2007 | 07:51 PM
Elton's Avatar
looks good i woudint mind adding some gauges in mine
Old Feb 9, 2007 | 08:09 PM
4Crawler's Avatar
Yep, sender plumbed into the fuel injector rail and a 2nd sender plumbed into my on-board air system. Select between the two with the small switch next to the gauge. Works great.
Old Feb 9, 2007 | 08:15 PM
PabloA's Avatar
Nice setup,
I see fuel pressure but what are the others?
Old Feb 9, 2007 | 08:21 PM
4Crawler's Avatar
Fuel and OBA pressure on top, Air/Fuel meter and a manifold vacuum gauge on the bottom.
rusty904
Mar 27, 2017 05:20 PM
Esibnitsud
Jul 30, 2015 08:19 PM
Nickyodaman
Jul 27, 2015 12:13 AM
TDonkey
Jul 26, 2015 10:14 AM
Poncho0206
Jul 10, 2015 06:21 PM
