Radiator Fan stopped working.
Old Feb 12, 2007 | 04:35 PM
ken.vs.ryu's Avatar
Exclamation Radiator Fan stopped working.
Drove 30 miles, turned of the truck for 15 min, started again, went less than a mile and it stopped.
Loud squealing noise, and smoke, the fan is not spinning. I can spin it by hand.
What's the fix?
The problem is that broken belt. I dropped it of at the mechanic. How much damage should I expect? Should I get all the belts replaced?
Old Feb 12, 2007 | 04:36 PM
95RunnerSR5's Avatar
you probablly need a new fan clutch
Old Feb 12, 2007 | 04:41 PM
ChickenLover's Avatar
The bearings in your fan pulley bracket probably seized up.
Old Feb 12, 2007 | 06:53 PM
ken.vs.ryu's Avatar
Limped to the mechanic and left it there. You can see that the belt is broken. What can I expect to pay?
Replace other belts?
I knew I shouldn't have been asking around for a new truck - this one got mad.
Old Feb 12, 2007 | 06:57 PM
If it turns out to be the fan pulley bracket, and you are having a mechanic do the work. Don't be surprised if you get quoted somewhere in the neighborhood of $1000.
Old Feb 12, 2007 | 07:21 PM
94RUNNER_SC's Avatar
You may get lucky and only need belts or a fan clutch. Worse case would be (and I know this because im waiting on mine to come from EBAY as we speak) You would need a fan bracket, A.K.A. fake (false)water pump bracket. Thanks to some help from some good guys here, I didnt pay the dealer $700.00 for just the fan bracket (less than 80.00 on EBAY). If you need the fan bracket, yours being a 92 V6 I think your fan bracket has a spring instead of the 93-95 Hydraulic tensioner. Correct me if im wrong here guys.Not a difficult fix if you have a 10MM and a 12MM socket, trust me.
Old Feb 13, 2007 | 05:01 AM
ken.vs.ryu's Avatar
Quoted 115 for the 3 belts. I'm relieved.
Old Feb 13, 2007 | 05:22 AM
CanTheWhales's Avatar
just get an electra-fan.... 160 bucks and no more belts or clutches ever...
Old Feb 13, 2007 | 07:00 AM
ken.vs.ryu's Avatar
Got the 2ND call and now the pulley was seized and needs to be replaced. Also getting the timing belt changed. 800 bucks.
Old Feb 13, 2007 | 08:26 AM
drew303's Avatar
$115 to replace belts, my god
Old Feb 13, 2007 | 08:42 AM
rezrunner92's Avatar
NAPA has that fan mount available now. My guys didn't have a listing for the fan or clutch but the mount was around 120 dollars.
voiddweller
May 20, 2021 07:58 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
jackiebrownia
Jul 20, 2015 09:02 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
