OIL LEVEL LOW, Please Help
Old Feb 10, 2007 | 05:31 PM
keithguts's Avatar
OK, I just had new HG's, Valve Job, Timing Belt, Water pump and other small thing done to my runner. It seems to be using 1qt of oil every 2000 miles. any help please. It is a 95 4x4 4runner with a 3.0 Auto. Also, I put aprox 100 miles a day on it doing high way driving.
Old Feb 10, 2007 | 05:53 PM
gaboonviper85's Avatar
does the exhaust smell odd? and is your front and rear main seals leaking?
Old Feb 10, 2007 | 05:55 PM
another thing you can do if you dont see smoke comming from the exhaust go out at night into a parking lot with street lamps and put the truck in neutral and floor it for a second and you may be able to see smoke.
keithguts's Avatar
smells normal to me. As far as any leaking, I been checking and never see a drop on the ground at any time.
Old Feb 10, 2007 | 05:58 PM
my truck has a front seal leaking....it never drips but on long drives it will sling oil everywhere and thats the only way you could even know its leaking....very small....doesnt do it while driveing around town but when i drive hundreds of miles it is definetly noticeable and like you have to add a quart every so many thousands of miles...look down by the main pully on the engine and you may see oil around there....or on the bottom of your hood.
Old Feb 10, 2007 | 07:16 PM
old4runner's Avatar
when i got my 87 22re it would go through about a quart every 250 miles or so. recently i pressure washed the engine compartment and replaced the timing chain and all associated gaskets (crank seal, oil pump, timing cover gasket, water pump) since then i have put about 600 miles on it and the engine compartment is nice and dry....when i pulled it apart it looked like the crank seal was where the worst leak was
Old Feb 10, 2007 | 07:24 PM
pruney81's Avatar
Do you think you might be burning it? Were you using any oil before you had all the work done. I just had my HG, timing belt water pump t-stat, valve seals, and other little stuff done as well and I used to use about a quart every thousand miles now after a thousand miles it hasn't leaked a drop. I have a 95 3.0 too 157k. If it's not leaking I'd take it back to the shop, could be your valve seals if you had a valve job...
Old Feb 10, 2007 | 07:26 PM
pruney81's Avatar
Although, Toyota does consider a quart every thousand miles normal use. So if you're using a quart every two for an 11 year old truck that's no big deal.
Old Feb 10, 2007 | 07:53 PM
slosurfer's Avatar
That's true, it says it right in the owners manual.
Old Feb 10, 2007 | 08:05 PM
itsmeagain5789's Avatar
huh, i had no idea about that fact, myne doesnt burn any, just leaks alot. it loses about half a quart every month. my mom is the biggest one concerned about the oil stains in the driveway. o well...
Old Feb 11, 2007 | 12:24 AM
Just Learning's Avatar
its suppose to leak #1 to keep frame from rusting, #2 self cleaning, the mud falls off on its own
Old Feb 12, 2007 | 08:55 PM
notanymore's Avatar
1 qt every 2k miles is not bad at all, before my engine died i was having to add 1qt every 200-250 miles
Old Feb 13, 2007 | 07:21 PM
PabloA's Avatar
this is interesting,
my 22re does smoke white, what could this be? Iam not loosing cooling fluid, I do know that.
It smokes but doesnt smell to funny. And also will almost make a puddle of water right below the end of the exgaust pipe.
Eggslinger
Jun 8, 2019 03:32 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Coreyr384
Jul 10, 2015 11:13 AM
akaphilly
Jul 9, 2015 02:18 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
