engine wont run
Old Feb 13, 2007 | 12:44 PM
Jay1's Avatar
engine wont run
I have a 91 yota pickup with a 22re 5spd 4x4. I just rebiult the engine and the motor dosent want to run. If I put it on TDC and turn it over a coulpe of time the rotor ends up on #3 when TDC But it should be on #1 cylinder. Any body have any comments about this?
Old Feb 13, 2007 | 12:57 PM
snap-on's Avatar
timming is off. you need to double and tripple check the timming belt (cam to cam to crank relations) and the distrubutor postion
there are quite a few posts floating around for all of the above problems.
Old Feb 13, 2007 | 01:04 PM
Yotapup's Avatar
http://personal.utulsa.edu/~nathan-b.../5distribu.pdf
Old Feb 14, 2007 | 08:17 AM
Flash319's Avatar
You have to go around 2 times to get back to #1 on the distributor. Distributor turns at half the speed of the crank.
Old Feb 14, 2007 | 01:06 PM
tampabayota's Avatar
pull your valve cover to make sure tour at tdc
Old Feb 14, 2007 | 01:25 PM
dcg9381's Avatar
Both people above are right. The distributor doesn't return to #1 based on a single crank revolution.
Old Feb 14, 2007 | 01:49 PM
i learned that this week !!!!!!
Old Feb 14, 2007 | 08:38 PM
Jay1's Avatar
and if that dosent work any other ideas?
Old Feb 15, 2007 | 05:51 AM
rdlsz24's Avatar
Yeah check out this thread: https://www.yotatech.com/forums/f116/moving-timing-chain-106859/
Rob
Old Feb 15, 2007 | 06:28 AM
maxpower_hd's Avatar
Also make sure you don't forget the ground wire on the back of the motor to the firewall.
Old Feb 15, 2007 | 08:56 AM
drew303's Avatar
Mine broke off with the body lift... tho im running the carb, not EFI..
what significance does this ground have? Comparing it to the ground at the base of the engine nearese the battery.
Old Feb 16, 2007 | 02:53 AM
I don't really know why but mine wouldn't start without it. It would just crank. Someone told me to check it. I ended up making a new beefier one and everything was fine.
Old Feb 16, 2007 | 03:27 AM
TOYZILLA's Avatar
22re wont start
Just put your #1 plug wire in the cap where your rotor is pointing on the cap.
Old Feb 16, 2007 | 11:08 AM
rdlsz24's Avatar
I bought mine with a body lift and no ground strap. I believe it helps avoid corrosion of the head. DC power and acidic liquids (which the coolant can become with time) combine to corrode metal very fast (learned that on MythBusters lol). I think the ground strap combats that. With that being said, should I make myself a ground strap? Anybody have pics where it connects on the head and firewall?
Rob
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
