Small black connector at starter
Old Feb 16, 2007 | 06:40 AM
mtrdrms's Avatar
What does it do and do I need it to start? My harness is mangled from engine swap and this is one of the casualties. 89 22re
Old Feb 16, 2007 | 06:45 AM
rdlsz24's Avatar
There are 2 connections that go to the starter. You have the little one you are talking about that slides onto a prong. The other one is the wire from the battery that bolts to the bottom of the starter. I'm not positive, but I believe you need both wires. If all else fails, give it a shot without it hooked up lol.
Rob
Old Feb 16, 2007 | 06:49 AM
snap-on's Avatar
the little black connector slides onto the tang for the solonid. the key switch sends 12 v to the solonid via this wire, the solonid fires and makes the high amp conneciton to to the battery via the BIG wire.
with out both your starter will not start
Old Feb 16, 2007 | 06:59 AM
sat4soris's Avatar
It goes to the ECU. I believe it's the STA pin on the ECU.
Old Feb 16, 2007 | 07:02 AM
mtrdrms's Avatar
Thanks snap on. I am gonna have to figure something out
okamikai
Apr 30, 2018 10:19 PM
mussy01
Dec 13, 2016 08:20 PM
steve miller
Oct 10, 2015 01:40 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
