Brake Light in cluster?
Old Feb 16, 2007 | 03:56 PM
ShortyzKustomz's Avatar
I just got my truck 3 days ago, I've drove it well over 200 miles so far, and since the first time I used the ebrake, the light on the dash wont go off? The ebrake is all the way in and the pedal is perfect. Any ideas to a reason for this, If not, I'll prolly end up yanking the bulb
Old Feb 16, 2007 | 03:57 PM
Elton's Avatar
check the brake fuild
CJM's Avatar
CJM
Brake fluid low, add fluid.
Old Feb 16, 2007 | 03:59 PM
Fluid is to the top, pedal is great
Old Feb 16, 2007 | 04:05 PM
CJM's Avatar
CJM
Your 100% sure it has enough fluid, even if its off a tiny itty bit and looks full it may be a little bit low and sending off a signal. Mine was and I added maybe 2 tablespoons worth and it went away.
Otherwise did you lock your e-brake on overnight when it was cold-it didnt release possibly but it would be dragging.
Old Feb 16, 2007 | 04:12 PM
The truck had been sitting for a few weeks when I bought it, The light wasnt on when I started the truck but then I set the ebrake while I was cleaning the snow off of it and the light hasnt gone off yet. And thats been 3 days of driving it
Old Feb 16, 2007 | 04:14 PM
Elton's Avatar
look under the dash and look at the switch for the e-brake make sure the handle pushes it all the way in
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Esibnitsud
Jul 30, 2015 08:21 PM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
