Is this True (Oil Question)
Old Feb 12, 2007 | 04:42 PM
keithguts's Avatar
Is it true that all 3.0 engines use oil. I used 1 qt in 3000 miles after having the compleat top end re done. I have no smoke, or any signs of oil on the ground under the rig.
Old Feb 12, 2007 | 04:47 PM
Bill's Avatar
This would be what, on Pirate4x4, is refered to as a "tuesday question".
Is someone else using your logon?
Old Feb 12, 2007 | 04:49 PM
JEBSR5's Avatar
Originally Posted by keithguts
Is it true that all 3.0 engines use oil?
If it is, I have the pearl in the bunch.
Mine doesn't.
Old Feb 12, 2007 | 04:52 PM
MudHippy's Avatar
Well I'll be....... Choices,choices,choices......Decision, refrain could back-fire, brutally. Oh burn oil, probability high, I'd venture to geuss, from pers. exp., I blame it on that sneaky oil(100% synthetic) I use. I also have rebuilt 3vze.
Old Feb 12, 2007 | 04:57 PM
da_bigg_wigg's Avatar
Mine uses olive oil. It's healthier.
Old Feb 12, 2007 | 04:59 PM
itsmeagain5789's Avatar
mine doesnt use any, just leaks. i have heard of that though. but i only believe it to a certain extent.
Old Feb 12, 2007 | 05:01 PM
navyredneck's Avatar
I can tell you that I was using 1.5 qts per 3k miles until I auto-RX'd the engine. Now the rear main oil seal leak has stopped and I'm down to a little less than a quart per 3k miles. I think the rest is maybe piston ring leak-by by with a few leaks from my front left cam seal which will get replaced if the timing belt ever goes...
Old Feb 12, 2007 | 05:08 PM
xcmountain80's Avatar
mine did, about a quart every 5000 miles or so.
Aaron
Old Feb 12, 2007 | 05:11 PM
keithguts's Avatar
I donot see any oil at all bu the rear or frount maim seals. or do I see any drippings on the ground. Where can it be going?
Old Feb 12, 2007 | 05:19 PM
littlerunner's Avatar
1 quart is well within specs for oil consumption.should it or should it not whos to say.toyota says 1 qrt in 1200 miles is acceptable.mitsubishi says 1qrt in 1000 miles is acceptable.neither would be acceptable to me,but 1qrt in 3000 does'nt concern me a bit.heck,its time to change it then anyway
Old Feb 12, 2007 | 05:37 PM
gohawks's Avatar
ALL motors burn SOME oil.
Old Feb 12, 2007 | 06:10 PM
95ToyotaPU007's Avatar
mine is about 1/4 quart every 3500 miles
Old Feb 12, 2007 | 08:33 PM
CyMoN's Avatar
i was losing 1qt every month then I replaced my valve cover seals so far no leak anymore and no loss of oil like it was.
Old Feb 13, 2007 | 05:19 AM
amgraham's Avatar
You have to remember that even though the top end is new the rings and cylinder walls are old. Many times a new top end will increase oil consumption (puts more stress on the rings since everything is now sealed up top). Still, 1 quart every 2-3K seems reasonable to me and is probably not enough for you to notice any smoke.
Old Feb 13, 2007 | 07:39 AM
thook's Avatar
I hope that's extra virgin....
Old Feb 13, 2007 | 09:07 AM
rezrunner92's Avatar
I agree with the above. Mine doesn't seem to noticeably consume oil. At least it didn't before. It just leaks now.
My wifes Camry uses about a quart every 5000 miles. I discovered that once when I didn't change the oil on time.
Old Feb 13, 2007 | 07:22 PM
Targetnut's Avatar
I know this is an old thread, but I'll chime in with my observations.
First 1qt/ 3000 miles is certainly acceptable for an old engine. even if the top end was redone.
second, this rate of consumption usually won't create visible smoke.
Old Feb 13, 2007 | 09:23 PM
Mister Willie's Avatar
Mine uses about the same, 1qt per 3000
Old Feb 14, 2007 | 04:04 PM
^VooDoo^'s Avatar
Oh shut up whiners, I use 1qt about every 1k, Change on 2k and its still clean.
Old Feb 14, 2007 | 04:08 PM
pruney81's Avatar
Yea right! My 3.0 used to use 1 qt per 1000 before I changed my headgaskets, I'm not sure how much it will use now but I'm hoping less. I'll be happy if it's only 2 qts. per 3000 miles
