Anyone reuse thier clutch?
I am wondering if I should reuse my clutch or change it while I have the engine out. It looks to have alot of life left to it and I always like the stock clutch over aftermarket on these trucks. Also which way does the clutch plate face?
look at it this way, would you rather spend the money now or 6 months down the road deal with it again, its just alot less labor, personally i would replace it, i am when i put my engine back in
it's hard to say. if it's got a bunch of life left on it, I'd re-use it. I've re-used a couple clutches on my old subarus...
IMHO, clutches are expensive....I'd rather do some extra work to get my $$s worth out of the one I have. but it's up to you. if you want to prolong the job as long as possible, buy a new one and replace it now....
I re-used mine too. However it did only have a couple thousand miles on it too. The guy that owned it before me put a new clutch in it and then a few months down the road, the motor spun a bearing.
But if it's got a bunch of miles on it then I'd go ahead and replace it. You will kick yourself if you're lying under there in 6 mos doing the clutch when you could have done it sittin on a stool.
i bought a lifetime warrantied clutch if i pull the tranny it goes back.... also having your flywheel resurfaced with a new clutch will help it last longer and will help cut down on that annoying chatter.
Anytime i have ever had a motor or transmission out , I replace the clutch.. I don't know about you but i don't really enjoy laying under 1 with grit and dirt falling in my eyes
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
