Power steering pump... question
Old Feb 8, 2007 | 07:52 AM
the"RoadRunner"'s Avatar
Hey everybody,
I had taken my 4Runner to the dealer I bought it from to replace the fan bracket, I didn't have alot of engine experience yet. I noticed that since I got it back there has been an insainly large power steering pump leak. I've been going through at least 1 bottle of fluid every week. I can't find right where it is leaking from but drips from right under the pump itself. I was wondering if any of you had the same problem and if so where you found that the leak was coming from?
Zach
Old Feb 8, 2007 | 08:22 AM
Tdubbs05's Avatar
i'm having this same problem since i flushed my power steering fluid, just not as bad. What i'd do is spray the area out with a hose so you can see where exactly it's coming from. most likely it's coming from the hose coming out of the pump, because that's the high pressure line. see what you can do about finding where the leak is coming from and then go from there. it maybe be a simple fix and all you'll need to do is replace a hose clamp.
Old Feb 8, 2007 | 08:43 AM
mt_goat's Avatar
Yeah mine leaked too. I replaced all the o-rings and seals because I couldn't tell which one was leaking:
http://members.cox.net/stacewilliams/ps-pump.htm
Old Feb 8, 2007 | 09:14 AM
rdlsz24's Avatar
I had to replace the hose that goes from the fluid cannister down to the pump. Mine was checked really bad and the fluid was squirting out. It would run towards the front of the truck and drip off my driver's side tow hook. So far it looks like replacing that hose has fixed it.
Rob
Robrt32's Avatar
I can turn my wheels all the way to the left and my truck shoots fluid from somewhere , seems to be worse backing up.. I haven't found the problem yet.. Its not much because it very seldom needs any , but smoke comes from under the hood when does do it.. I just try not to turn it all the way.. When it warms up some i will locate the problem
Old Feb 8, 2007 | 09:49 AM
drew303's Avatar
New pumps are around $150.
fyi =)
Probably source one from a junkyard CHEAP. thats what I'd do.
Old Feb 8, 2007 | 11:49 AM
Tdubbs05's Avatar
lol yeah if i were you guys with the fluid squirting i'd get that prob fixed right away. I really hope my leak isn't coming from the seals...
Old Feb 8, 2007 | 02:55 PM
leebee's Avatar
the p/s pump isnt all that difficult to check. more than likely, its going to be a hose or an 'o' ring. loosen the belt, undo some bolts and take the thing to the bench. replace the 'o' rings and the hose, reassemble, top up the fluid and check for leaks.
you already know what causes it to leak, test it out and you will know if your repair was successful.
keep us posted.
lee
Old Feb 8, 2007 | 03:34 PM
alright. that sounds easy enough. removing the pump isn't something that i normally would do cause i wouldn't want to break anything. however, i just started my engine semester at tech school and have already taken off several p/s pumps. if i'm correct, you don't have to mess with any timing belt covers right?
Old Feb 8, 2007 | 04:58 PM
mt_goat's Avatar
That's right.
Old Feb 8, 2007 | 07:59 PM
toyota_mdt_tech's Avatar
Leak is more than likely coming from the rear round cover o-ring at the back of the pump. We install a complete seal kit for these. Common w ht age/miles. Kit is about $35, and the ones for 90-94 is the same, and for some reason, the 95 kit is different. We stock the kit and its not too tough to do.
Old Feb 8, 2007 | 08:36 PM
thanks for the help so far. i went out about 10 minutes ago with a blue flash light that i find very helpfull with turning liquid into bright colors at night. it is coming from the back of the pump near that o-ring. is this something that can be replaced without taking the pump out of the vehicle? also if removal of the pump is neccesary, what things do i need to do (i know p/s pumps have alot of pressure and that i'll probably need to bleed the brakes too)?
Old Feb 9, 2007 | 04:28 AM
mt_goat's Avatar
Yeah you'll have to take it out. See the link in post #3. You don't need to bleed the brakes (even if you have ABS) but you may need to bleed the PS system. https://www.yotatech.com/forums/show...power+steering
The hardest part of the rebuild can be removing the pump pulley as they can get rusted in place pretty good. I heard one guy tried to use a gear puller and bent the pulley so don't do that. I got mine off ok but I don't have much of a rust problem.
Old Feb 11, 2007 | 10:08 AM
leebee's Avatar
here is a link to the fsm for the p/s ass'y:
http://personal.utulsa.edu/~nathan-b...11powerste.pdf
im pretty sure there are more than a few postings on here regarding p/s issues. do a search and have your reading glasses handy!
lee
Old Feb 11, 2007 | 01:42 PM
drew303's Avatar
You have the 3.0?
I'm not familiar with the 3vze at all so i dont know how the pump fastens.
On the 22R,E, TEC whatever.. 22 engine the pump is held in with 4 bolts underneath the Distributor.
12mm to loosen the tensioner pulley and a 19mm to release the locking nut (that keeps the pulley tight to the bracket it fastens to).
release the belt, take it off, 14mm bolts holding the PS to the bracket, take the hoses off... your gonna lose fluid so get a rag handy. I guess I'd just try and put them higher than the resevoir so it doesnt drain out.
pull it PS out.
on a 22re
Old Feb 11, 2007 | 06:04 PM
Cebby's Avatar
Thanks for the link Dale. I have the stuff to rebuild my 3.0 pump - might as well before I sell it.
Old Feb 12, 2007 | 03:58 AM
mt_goat's Avatar
lee
Yeah lee that link has better detail. I used them both when I did mine, and also checked the tolerances.
glowz825
Jan 25, 2022 09:28 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
keithporter83
Jul 24, 2015 07:37 AM
jon.r
Jul 11, 2015 03:34 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
