more details on sea foam in 22r carbed engine please
Old 02-09-2007, 08:19 PM
gaboonviper85's Avatar
i read the huge thread on sea foam but it touched very little on carbed 22r engines.... can any of you go into more detail on this for me? 1986 22r
Old 02-09-2007, 08:25 PM
harpen123's Avatar
I seafoamed mine but cant provide any insight as I blew a hole in the block within 3 days.
Old 02-09-2007, 08:27 PM
that scares me!
Old 02-09-2007, 10:04 PM
drew303's Avatar
I seafoamed both my 22R's (carb)
no problems here. Not sure if it helped any....
and i dont see how you could blow a hole in the block from seafoam?
Also when you are adding it you only add it at a rate where the engine is still running. Which will feel painfully slow as the engine will really want to cut out. (putter putter)
Then you shut the engine off, let 'er chill for 5 minutes.. start back up and you will get a huge cloud of smoke, grey/white whatever. then it'll burn away and you're done.
Old 02-09-2007, 10:06 PM
do i pour it straight down the carb? and if so which barrel?
Old 02-09-2007, 10:10 PM
and if you pour it down the carb how is it going to coat the valves cause it wont be able to atomize will it? so many questions such little time
Old 02-09-2007, 10:19 PM
drew303's Avatar
I just followed the directions on the can.. as for which barrel... either, alternate, dont matter. its going in the engine either way :-p
Old 02-09-2007, 10:21 PM
ok thats all i needed to know! thanks!
Old 02-09-2007, 10:38 PM
drew303's Avatar
like i said i dont know how much it helped. I didn't care to look through a plug hole to see a before and after of the amount of carbon buildup on the piston heads... I just did it becuase I've heard it works.. so wtf, its cheap why not give it a go =)
I also through some in with the oil.. and the gas tank. No noticeable difference in performance on the 4wd rig but it was running fine before.
the 2wd i figured it had to help clear out the carbon buildup from running rich for so many months.
Old 02-09-2007, 11:39 PM
Just Learning's Avatar
harpen how did you blow hole in your block, what part of engine escaped??
Old 02-10-2007, 07:58 AM
so far i dont know if the sea foam is makeing a difference but it sure is hella fun smokein up my neighborhood!
Old 02-11-2007, 12:38 AM
seee your the reason for global warming just wait till al hears about you :0 oh yeah i heard someplace is in like 7 feet of that cold white crap
kazuya2416
04-05-2024 02:17 AM
sandyota
02-04-2021 11:16 AM
Yota.Jay
07-23-2015 08:08 PM
cars-guy
07-11-2015 07:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: more details on sea foam in 22r carbed engine please
