- speedometer error/replacement gear options
- 3.0 misfiring after body swap
- What do you have for your 3VZE Exhaust?
- 3vze dies and wont start
- Issue with my 86' 4Runner
- over heating. HELP!!!
- 1986 Toyota Pickup Runs Great but Stalls
- 1994 Toyota Pickup Idle Surge
- oil sender gauge wire does not reach????
- 3vze has horrible gas mileage and runs perfect
- '94 4WD pickup 22RE engine runs 3 2 seconds then dies
- falling headliner?!best way to fix it for GOOD?!
- Reading Spark Plugs
- Oil pressure sending unit location
- 92 4wd p/u speedo wiring question
- Infinite radiator air bubbles
- One Windshield Wiper Not Working
- Installing Gabriel Steering Damper #6804SE but it don't FIT!!!
- New '86 - Suspension ?
- Rear axle bolt pattern
- Another Noisy V6
- 22RE massive oil leak help.
- oil leak
- Do my tie rod ends, and ball joints look bad? IFS
- Figured out why my transmission pan was leaking...
- 3vz muffler exploded...is this normal?
- weber jets... running rich which is which?
- 87 runner .Need Help Major Start Issue
- 22rte cold start issue
- 94 4x4 fuel pump bracket
- new speakers
- 3VZE Sensors
- 22re dies once warm and will not restart until cool again
- 88 4runner rear bumper mounts
- Dually 1 ton flatbed??
- No power 22RE in rain? Here's the solution :)
- 3vze engine knock? or a normal noise and im just paranoid?
- 4wd after trans swap
- AC Fan Speed Resistor $1.99 Mod
- exhaust & intake mods
- Help: Hydraulic Timing Belt Tensioner
- 1987 22re Rough Lopy Idle and Missing
- 88 4x4 pickup breaking issue pulls hard left, need help
- 88 22re overheating ?
- '94 Pickup 22re idle problem
- a/c amplifier pin out with walues
- 95 4runner 3.0,overheat, cold heater,thermostat or water pump?
- possible fuel leak??
- 88 dtc 21 after new sensor, sensor/short caused ecu problem solved/repaired
- A-Frame the rear shocks ?'s
- Random Check Engine Light
- bed removal help
- 3vze - Oil coming from Headgasket
- 95 3vze ticking, does this sound normal?
- 86 4runner temp sensor or sender??
- 95 runner not getting fuel!
- Is the 3VZE just loud?
- no more pinging
- Acceleration Issue when motor is cold
- 91 trans rebuild kit question
- Idle RPMs?
- Couple of general questions
- What to do with ratty old seats?
- Had to replace my CV the other day..
- 0-60
- steering spindle/knuckle replacement
- 87 Toyota want run HELP.
- heater valve on firewall, (leads to core)
- bad oil leak on the passenger side of block
- sr5 4runner dual cases
- o2 sensor check engine light on
- 89 3.0 Oxygen sensor question.
- can't control idle on 22re, goes to 6000rmp @ start-up
- Question/comment on Brake Booster
- 3.0 making knock sound!
- Will a 94 4runner Rear axle shaft fit a 2000 4runner rear housing?
- 91 4runner 22re no power
- Fat Bob's Garage Lift Kit
- timing off a tooth? WITH PICS!
- Rolled her :(
- Head tuning 3vz-fe, ignition optimizing? How?
- First yota build 87
- auto to 5speed console swap.
- Help! timing chain job gone bad?
- Tranny or t case noise
- 3VZ-E.... HELP! Ideas for breaking cam sprocket bolt with loctite on it?
- BJ spacers W/ low pro BUMP stops
- Rear disc conversion
- higher Hardtop / 1. Gen 4Runner
- If a timing chain breaks...
- Fender clean up after a cut and inner fender question
- Bad clutch slipping, what is going wrong with it???
- Fuel Gauge/Sender ohms?
- 86 4Runner steering wobble and vibration
- Stumble, Misfire on 3vze
- Scored at the junk yard
- HELP!!! 95 4runner Overheating under load
- stripped the bolt on my Transmission fill...Alternate Fill method?
- steering column
- Which clutch do I need?
- Auto tranny shifts question
- Obx header
- Will these springs work for a ZUK mod?
- Can't get 93 to run right
- rough idle, re-wire, now high idle?! gutless 22re
- rear oil leak
- Cheap ISR mod for 3.0L
- is this illegal: engine swap - newer engine in older truck
- repainting questions
- Yea!!!! Brakes!!!! pull left or right
- zukn mod rides horrible
- 4 wheel drive problems
- 95 runner fan mount bracket
- isr mod
- Anyone install 1st gen inclinometer into 2nd gen WITH write up?
- clutch master cylinder...clutch pedal
- broke my timing chain guide, time to rebuild (pics)
- 89 3.0 no heat
- Looking for an adapter to fit our trucks towing harness for a trailer w/ a round one
- 3vze no spark from distributor
- wooooosh when cold...and when it's warm?
- PLEASE HELP: battery charge and parking brake light on.
- Can my thermostat cause this problem?
- symptoms of a blown clutch?
- Auto turbo ecu in a Manual Trans?
- Altering Cruise Control
- Rear upper shock mounting help
- Stock Mud Flap interchangability?? Runner fit on truck??
- How many clutch MC's should I buy this time?
- MONSTALINER Review
- Thought i had rod knock, bearings good, but maybe it's from bellhousing area?
- resonator question
- Parts needed to run 22re
- Transmission woes
- Replacing broken Seal on inside of front half shaft
- 3vz bogging down under load with whistle
- Engine Wires
- not your typical brake/charge light problem
- Can I swap Timing Belt tensioner in 3VZE.
- Groaning when turning in reverse = bad hub?
- cam shaft end play measurement?
- 92 4Runner will not start when warm
- Build pictures, and cost of build
- Rebuilding 3VZE -- Thrown Rod causes & reusing rusted crankshaft?
- Speed sensor- walks like a duck, quacks like a duck...
- 5speed swap question
- Back side window of extended cab window bolt?
- high co%= failed smog (HELP)
- another key question!
- taigate lock? any ideas
- 89 sr5 front diff
- 3vz starting/driving problem?
- Driving without CV's?
- How long do your front pads last?
- 88 3.0 to 94 4runner
- 87 4runner totalled, picking up 88
- ZUK Mod - No Cut - 96-98 Runner Coil Springs
- Aftermarket or OEM cylinder head?
- Help stuck in Vegas!!!
- Engine Fuse, rear window and no center console power
- What else do I need?
- Getting 22re fired up questions
- Temperature overshoot
- motor swap
- EGR trouble, Code 71
- Trailer Hitch fit-ment question
- how to remove fuel pulsation damper on '88 22re?
- toyota rv 3vze headers!
- new blazeland lift
- sloppy transmission
- first gen runner gas tank-too low?
- rear drive shaft lengths
- CA Emissions - The joy of it all
- 4runner 3rd gen bumper on 2nd gen
- New Starter looks different than the one I'm taking out of my 22re PICS INCLUDED!!
- help! 88 toyota truck 22r problem
- brake troubleshooting
- 94 22re 4x4 pickup star and die problem
- No Spark 86 22R pickup - Desperation row
- smittybuilt bumpers?
- Zuk vs ome's
- 86 4runner bad gas mileage and low power 22re
- 22r refresh
- Fuse 8 in 1986 22R 4x2 Manual
- aftermarket sheet metal parts fit
- Rod knock and bearing fit questions, how much "wiggle"?
- toyota turck brake portioning valve
- Replacement leaf springs for hauling?
- New to me 88 4runner have several questions!
- Need help with getting my 22re running! PLEASE HELP!
- My new orphans.....86 ext cab & 87 std cab
- 91 3.0 vacumes clogged
- how hot is too hot?
- Odd heater issue.
- 95 automatic transmission
- 87 4runner transmission help
- 1994 toyota pickup NO START 22re
- Another mystery knock thread
- 87 22re 4runner white smoke while warming up
- 90 5 speed 3.0: temp reading/idle issues
- Header
- piston install
- Swapping seat rails q's
- Has anyone done an IFS differential rebuild?
- I have a problem when I start my new 4Runner
- Code 13 - Crankshaft position signal
- Engine noise, with video
- spun rod bearing
- not sure which msd coil I need for 22re?
- ground straps
- Engnbldr head, cam and header question
- Diff play
- 1989 22RE starts only when jumped
- A340h trans
- Unplugged Connectors HELP
- Help! 86 turbo 4runner won't start.
- having door lock wiring issues
- 3.0 3vze Coil and Igniter Compatability 95 Runner to 92 PU
- Truck overheated what do I need to do now?
- 89 22r deceleration afterfire
- diesel noise
- 95 SR5 4runner engine knock getting louder
- air filters
- PAIR tubes & EGR
- Sub Harness Issue...Wiring
- Mass Air Flow Sensor
- First Engine Build
- New ps pump fail x2
- 89 toyota pickup major problems
- 88 4runner license plate lights
- tc cover question
- Ignition Timing Problem: Mark slowly revolves around crank pulley, not steady
- VSV question/help?!?!
- 93 PU 4WD 22RE fuel pump fuse
- Adding A/C system...how difficult???
- A/C Question: '89 4runner
- power gain
- Driveline Vibration
- Hawkstrongs Headgasket replacement
- timing issue or something else
- 22re fires, runs for 3 seconds then dies...
- Warm start not getting enough fuel
- Towing question
- Cup holder install in 1987 4runner
- 91 Pickup 3vze Missing Randomly (Desperate!)
- New clutch and im still stumped
- 3vze belt replacement
- gauge installation - wire color question
- loss of power steering in low rpm's
- vin plate thread
