4 wheel drive problems
Old Mar 27, 2011 | 07:21 PM
runs-on-4's Avatar
i look at a 86 pick up today , everything was good during the test drive until it went into 4 wheel drive. it sounded like the drive shaft was binding up and making the whole truck bump. what could this be from
Old Mar 27, 2011 | 07:29 PM
T_F_E's Avatar
Were you on pavement, did it occur when turning if so thats normal and dont do it again. Other words you might have different tire sizes or even gear ratios.
Old Mar 28, 2011 | 10:44 AM
runs-on-4's Avatar
I tried it on pavement and gravel going straight and it has stock gears and 33's and it only happens when the hubs are locked
Old Mar 28, 2011 | 11:00 AM
justin_4runner's Avatar
i had a problem like that and it was bad cv shaft, but if the u joints are bad that could cause it too.
Old Mar 28, 2011 | 11:02 AM
Bojangles's Avatar
4-low always binds up just a little bit at full turn, But going straight there shouldn't be a problem.
Either there are different gear sizes front and rear, or your cv's could be bad.
(Assuming its something small)
Old Mar 28, 2011 | 12:46 PM
runs-on-4's Avatar
could the cv's go bad from sitting the guy hasnt driven it for a year or two
Old Mar 28, 2011 | 12:51 PM
runs-on-4's Avatar
and he said everything worked when he parked it
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
