Mass Air Flow Sensor
Old Mar 18, 2011 | 06:49 PM
mikebo123's Avatar
1990 4runner 3.0
I took the mass air flow sensor with the intention of cleaning it. I found out that it does not have the two wires to clean as I hoped. After putting it together and back on the truck doesnt want to run. error 31
I cleaned the connectors took it apart again and same problem. The truck was starting to run a little rough after it warmed up and thats why I was cleaning it. These things are $$$$ to replace. Any other sugeestions would be greatly appreciated.
Uploaded with ImageShack.us
Old Mar 18, 2011 | 06:57 PM
justin_4runner's Avatar
did u pull the side plug out or the top cap? if u pulled the side off then u will need to pull top cover and soider the connections again if u do a serch u will find other threads to fix it. if u didnt pull it apart and sprayed stuff in it then u might want to pull top and clean out the liquid that might be up in the cap area.
Old Mar 18, 2011 | 07:08 PM
mikebo123's Avatar
I did pull the plug out a little to look.
Old Mar 18, 2011 | 07:33 PM
yeah u pulled the connections off in side the top area, so cut the silicon off of the top and remove, black cover and then re-solider the connections put black cap back on and seal. then try running the truck.
Old Mar 18, 2011 | 07:55 PM
mikebo123's Avatar
Thanks alot for your help.
Old Mar 18, 2011 | 08:44 PM
RMA's Avatar
RMA
if for whatever reason you cant get it to work .. i have a good working one $25 plus shipping ..
Old Mar 18, 2011 | 08:48 PM
mikebo123's Avatar
I'm my try to get one from the salvage yard or fix the one I got. But I may get back to you. That sounds like a great price.
Thanks
Old Mar 19, 2011 | 06:53 AM
mt_goat's Avatar
Its not a MAF, its an AFM and they don't usually ever need to be cleaned.
Good luck soldering all the little conections back to the circuit board, I did the same thing once. It will test your soldering skills.
Old Mar 19, 2011 | 07:14 AM
mikebo123's Avatar
Thanks ! Live and learn!
Old Mar 19, 2011 | 09:15 AM
BigBluePile's Avatar
Live and learn.....AND use the search button!
Old Mar 19, 2011 | 10:53 AM
mikebo123's Avatar
Fixed! Thanks for all the feedback and help.
krimsonone
Sep 13, 2024 09:33 AM
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
jetpilot
Aug 15, 2015 06:48 AM
