89 22r deceleration afterfire
Old Mar 19, 2011 | 10:26 AM
Jeremy28c's Avatar
My 89 truck with a 22r will afterfire if I suddenly let off the throttle if Im going above 50mph. If I drive it for longer than 30-45 minutes it goes way and the idle smooths out. I just put a tune up on it and changed the pvc valve and fuel filter. What has me confused is why it goes away after its been ran for so long. I gets up to operating temp in about fifteen minutes but doesnt run better for right away. Any thoughts???
Old Mar 19, 2011 | 01:10 PM
Jeremy28c's Avatar
just a side note. Im not sure why but when I relieve the pressure on the fuel tank it seems to run better right away. Also there are no engine codes to help diagnose the problem
Old Mar 20, 2011 | 08:00 AM
swampfox's Avatar
If the motor is a r and not a re it will not show a check engine light, because it doesn't have a ecm. it might have a restricked vent line causeing it to build pressure ,which could cause a flooding problem.
Old Mar 25, 2011 | 01:20 PM
Jeremy28c's Avatar
Well. Figured out it was the auxiliary accelerator pump. Just plugged it off till I get a new one to replace it. Runs great. Hope this will help out with the mpg. Thanks for the help
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
