rear oil leak
Old Mar 28, 2011 | 02:31 PM
Dufek125's Avatar
rear oil leak
So after an engine rebuild on my 87 22re im leaking oil from the rear passenger side, it wont leak when running but will leak a decent amount directly after shutting it off and then will stop. the oil pan has been replaced and sealed properly, any help would be greatly appreciated.
Old Mar 28, 2011 | 02:59 PM
rattlewagon's Avatar
Get under your truck with some simple green and a rag and CLEAN EVERYTHING thats oily, then start your truck, pull the ebrake or block the wheels, and lie under it till you see oil coming out of somewhere. Or you mentioned it does it when you shut it off, so lie under it when some one shuts the truck off and see where its coming from.
Colington
Mar 8, 2020 09:51 AM
andrewtexas123
Jul 14, 2015 04:29 AM
Avenged
Jul 9, 2015 07:55 AM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
