resonator question
Old Mar 26, 2011 | 01:35 PM
shaunneuhaus95's Avatar
resonator question
what do these lines really do, can I just cap them
Old Mar 26, 2011 | 01:53 PM
toyota4x4907's Avatar
Which lines?
Old Mar 26, 2011 | 02:44 PM
Wrenchinjoe's Avatar
Do you mean the hose that comes off the top of the air filter box, goes to the resonator, then goes from the resonator to the large steel line that runs beneath the plenum?
If you remove your PAIR valve and cap the vacuum lines related to that then yeah you can ditch the resonator and cap the bib on the air filter box.
If you are keeping the PAIR valve in operation, just ditch the resonator and run some radiator hose from the air filter box straight to the steel line.
Sounds like the ISR mod would be good to consider
Old Mar 26, 2011 | 03:28 PM
so sorry i was trying to do this thread from my crackberry
Old Mar 26, 2011 | 03:31 PM
ok i cant get the image to load but yes those line from the resinator can i just bypass so i can remove both line with no effect on engine?
Old Mar 27, 2011 | 06:32 AM
heres the pic
Old Mar 27, 2011 | 07:18 AM
thanx wrenchin i did the search on the isr mod, and yes it sounds good
Old Mar 27, 2011 | 10:26 AM
scuba's Avatar
Download the photobucket app.
You need to copy over the [IMG] code once you upload an image to photobucket.
Old Mar 27, 2011 | 04:30 PM
Did the isr mod, need to make an adaptor at work tomarrow, then I can just hook an air filter right to the afm. Looks cool with all the airbox junk out.
montanatruck
Feb 26, 2017 07:07 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
4Runnin2000
Jul 29, 2015 06:09 PM
