HELP!!! 95 4runner Overheating under load
Old Mar 28, 2011 | 09:01 PM
lucasy's Avatar
Hey Guys,
so i have run in to a bit of a brick wall with this one...
I have just done the head gaskets on my 3zve.. installed some rebuilt heads, new gaskets and bolts etc etc. Also had my radiator rebuilt. Have installed a new thermostat, and drilled a hole in it to ensure no air blockages when bleading the coolign system. It also appears that the fan clutch is working, as it "roars" when you first start the car and i can hear it cutting in and out..
Now.. i can have the car running in the drive way and rev it etc and it sits at normal operating temp.. but.. if i go for a drive around the block, the temp climbs in to the red! both radiator hoses are hot, tho the top one isnt as hot as the bottom one. I belive i have blead the cooling system correctly.
Im stuck as to what to do next. i was thinking about running with out the thermostat to see if that makes a difference. only other thing is maybe the water pump aint happy?
any ideas guys? im getting close to pushing it out on to a main road and leaving it there!
Cheers
Old Mar 28, 2011 | 09:18 PM
justin_4runner's Avatar
i would see about parking where the front is higher and let it cool a little pull cap and let it run, let it cycle a couple times and run the heat inside the truck. see if u have air in the system or if the water pump is not moving the water it should.. when u did the work did u pull the water pump?
Old Mar 28, 2011 | 09:20 PM
lucasy's Avatar
ill have to give that a try.
Nar, i didnt pull the pump, as it was replaced about 8 months ago.
Old Mar 29, 2011 | 12:13 AM
lucasy's Avatar
ok.. so i have run the car with out the thermostat, and it seems ok! ... so either im bleeding the system wrong. or there is something wrong with the thermostat. I have watched the thermostat open in boiling water. but... looking at the manufactures web site for the thermostat, i notice they also sell a hi flow one..
TT242-180 Thermostat 08/1990 11/1995 Offset bypass type thermostat, 52mm main flange.
TT2042-180 Thermostat (High Flow) High Flow version of TT242-180, allows approximately 30% more coolant flow.
smthwsn357
May 1, 2024 07:28 AM
Rkellerman
Jul 12, 2015 08:42 AM
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
Nickdigg
Jul 7, 2015 06:04 AM
