not sure which msd coil I need for 22re?
Do you guys use the blaster2 or blaster3.If you use the three how do you attach the coil lead.Just put some new wires on the truck and shocked at how much better its running,figure I will replace 20 year old coil next.Thanks for help.
I have a blaster 2 that I'm thinking about putting on. I also have a msd 6A I have been thinking about putting on too but I can't figure out how to wire it on these trucks. Anway to answer your question from what I can tell the blaster 2 will work.
Neither.
The MSD coils aren't good on these trucks, and honestly won't help with anything.
You're better off with a new cap/rotor, and some good plugs.
Advance the timing a bit and set the gap a little bit wide, and it'll be a tad more efficient.
Vargntucson
07-04-2015 12:15 PM
