sr5 4runner dual cases
Old Mar 30, 2011 | 05:07 PM
knobs's Avatar
Im going to be puttin duals on my runner soon and was lloking at where I was gunna locate the shifter and I looks like it would be right where the rear window and wiper switches are, anyone got a good idear on that?
Old Mar 30, 2011 | 07:25 PM
rattlewagon's Avatar
Move the switches?
Old Mar 30, 2011 | 08:06 PM
knobs's Avatar
Well its part of the whole center console
Old Mar 30, 2011 | 08:07 PM
weaselman's Avatar
take it out and make custom?
Old Mar 30, 2011 | 08:39 PM
R.DesJardin's Avatar
Levers
Get a set of Forward Mount Rear Levers that put all three levers together. Save your center console that way.
Old Mar 30, 2011 | 09:39 PM
muddpigg's Avatar
cut it.
Old Mar 31, 2011 | 05:25 AM
mt_goat's Avatar
Dog leg shifters will also move it some:
More on that here: https://www.yotatech.com/1001175-post195.html
Old Mar 31, 2011 | 06:48 AM
FUNrunner87's Avatar
The part the switchs mount to pops out of the console. I relocated the rear window up/down button to where the clutch cancle button was, and got rid of the rear defrost button (didnt work anyway). The wiper, and window lock switches got moved to the epty spots right above the radio. I just rerouted the harness and extended where needed
Old Mar 31, 2011 | 06:58 AM
Cyberman's Avatar
Not to hijack, but how are you dealing with the rear driveshaft? In my extended cab pickup, the ds runs back, then down. Do you shorten the part that runs back? I'd hate to lose that part of the ds, keeps it tucked up to the frame.
Old Mar 31, 2011 | 06:59 AM
4Crawler's Avatar
Use a short throw kit on the rear case. I used to have the switches where my shock controls are located below:
Or I ultimately also moved my switches to the dash, they work so much better up there anyway, plus gave me a handy location for the shock controls.
Old Mar 31, 2011 | 08:11 AM
Ditch the whole thing get a 1 piece shaft. Or shorten the piece before the carrier. Depends on your rear flex/pinion angle.
Old Apr 2, 2011 | 08:07 AM
1badtoy's Avatar
Drill out the tac welds that hold the bracket that the 10mm screws inside the console thread into and move the console back
A2theK
Jul 12, 2015 10:46 AM
Cplmike
Jul 8, 2015 08:47 PM
raiderhawks00
Jul 8, 2015 06:23 PM
skoti89
Jul 6, 2015 07:45 PM
toyoda8488
Jul 5, 2015 10:18 PM
