1989 22RE starts only when jumped
Old Mar 19, 2011 | 09:29 PM
pitbull_myk's Avatar
The battery in my truck turns the motor over plenty fast enough that it should start. However, it will only start with jumper cables on it. Any clues?
Old Mar 19, 2011 | 09:59 PM
Blue 89 Runner's Avatar
Sounds like you need a new battery ...
Old Mar 19, 2011 | 10:11 PM
95blackToy's Avatar
yeah definitely replace the battery. I had the same exact problem in my truck.
Old Mar 19, 2011 | 11:40 PM
I am fairly confident the battery is not the problem. I have tried quite a few, although none were brand new, they were known, good batteries. I am having some other electrical issues as well, but would like to figure this one out first..
Old Mar 19, 2011 | 11:53 PM
ToyoTech559's Avatar
clean the connection between the terminal and battery. also check your battery wires. alot of times they corrode under the wire wraps
Old Mar 20, 2011 | 12:14 AM
vital22re's Avatar
totally a bro
chances are that you have corroded/dirty terminals and or battery cables. you won't be able to get good amperage from the battery through the cable.
Old Mar 20, 2011 | 01:01 PM
Plenty of amperage. Motor turns over pretty fast and it will start on its own occasionally.
Old Mar 20, 2011 | 08:07 PM
started at the battery cause there's nothing left to lose. Replaced wire to starter with marine grade high zinc wire from a boat. Cleaned battery wire ends to the relay/EFI fuse block thing on passenger inner fender then it ran perfect. Drove it to the garage from the back yard and let it get warm. While warming up I started bolting the relay block EFI thing back on the inner fender and when I grab it the motor bogs down...Might have this thing licked tomorrow.
bigjstang
Jun 2, 2025 03:56 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Whatever123
Sep 30, 2015 12:12 AM
colinmil
Jul 6, 2015 04:03 PM
CJ94yota
Jul 3, 2015 10:14 PM
