Replacing broken Seal on inside of front half shaft
Old Mar 26, 2011 | 12:38 PM
rottjr's Avatar
I recently acquired a free 1990 V6 4x4 4runner. It has a leak on the inside of the half shaft due to a "seal". I was told by the person who gave it to me that if I had to pull the half shaft to get to the seal I should just replace the half shaft. The boots look brand new and the half shaft looks to be in decent condition. What is your take on this? Also, I have the Mechanics manual on it, but it does not reference the seal. What is the actual name of it?
Thanks,
Rottjr
Old Mar 27, 2011 | 08:15 AM
eric-the-red's Avatar
Not sure what seal is leaking but the shaft has an inner and outer boot. They are replaceable but if one is split and leaking it is a lot easier to just buy a new/rebuilt shaft. If it's the side seal in the diff then you have to remove the shaft, pull the stub shaft from the diff and replace the seal. That's a fairly easy fix.
Old Mar 28, 2011 | 07:45 PM
rottjr's Avatar
Thanks so much for the fast response. It is the seal inside the front diff.
Old Mar 29, 2011 | 04:07 PM
If you're up to trying the fix yourself there is a link to a factory manual half way down this page. I've replaced one and it's doable with the diff still in the vehicle.
http://www.ncttora.com/fsm/index.html
voiddweller
19
May 2, 2016 09:10 PM
Niameyrider
Jun 25, 2015 05:50 AM
abalagtas
Jun 22, 2015 12:57 PM
Mr.Black
Jun 21, 2015 10:17 AM
