89 sr5 front diff
Old Mar 24, 2011 | 02:51 PM
fourbyfour's Avatar
89 sr5 front diff
so i figured out my problem today when i pulled off my front diff cover, 4 of the teeth sheared off one of the gears. now, i found a diff from a 90, 7.5 inch, but the truck had manual hubs, mine has ADD hubs. so this wouldnt work with my truck? not 100 percent sure
Old Mar 24, 2011 | 03:14 PM
rattlewagon's Avatar
You can swap hubs easy, the diffs are basically the same, its the long shaft going to the drivers wheel that makes it "add" or not, and can also be changed out easy. So in the end, you can run which ever hubs you want.
What you should be more concerned with is making sure you get the right gear ratio.
Read here: http://www.brian894x4.com/Gearratiosanddiffs.html
Old Mar 24, 2011 | 03:20 PM
fourbyfour's Avatar
yeah i know i have 4.10's but i dont really want to buy manual hubs either, so this diff wouldnt work for me because theres no place to mount that vaccum box or whatever its called right?
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
coffey50
Jul 28, 2015 10:55 AM
scottyg486
Jul 19, 2015 05:34 PM
TokyoD23
Jul 12, 2015 06:01 AM
