ground straps
Old Mar 20, 2011 | 05:43 AM
BigSwole's Avatar
ground straps
Ok guys I searched and wasn't able to find the correct answer.
I pulled my motor out and have installed another motor. This is been my first motor removal/install but its gone pretty good IMO. Problem I have ran into is the ground (I'm guessing) that is on the same lead as the starter wires. Where does it go. Where is the correct placement.
Also, at the end of the fuel rail I have a hose that I have yet to connect as I have no clue where it goes. Gas leaks out when u turn the key if that helps any...end of fuel rail closest to cab.
Auto transmission guys. The a340h where is the correct routing of the trans cooler lines. Above motor mount?
It is a 90 Toyota pickup 22re auto ext cab 4x4
I don't have access to internet ATM I can only use my blackberry so the more help the better. TIA.
Old Mar 20, 2011 | 06:15 AM
sebastianholmes's Avatar
the fuel rail should connect to the return hose. look for one leading back to the gas tank, its not big but not tiny
Old Mar 20, 2011 | 06:36 AM
BigSwole's Avatar
Ok then ill get that checked out pronto as I'm going to try and fire her up and get her moving under her own power again. just gotta get these few little things situated.
Ty for the help
Old Mar 20, 2011 | 08:36 AM
corax's Avatar
Ground wires can go to any bolt that is convenient, just match up the hole in the eyelet to the bolt you decide to use - don't use a 6mm bolt for an eyelet with a 10 mm opening
Old Mar 20, 2011 | 11:10 AM
BigSwole's Avatar
I thought the same thing just wasn't sure if it NEEDED to be in a certain place or not.
Any ideas on the transmission cooler lines?
Old Mar 20, 2011 | 11:34 AM
justin_4runner's Avatar
the ground wire on mine the big black wire connected to the motor mount bolt to the motor, and the cooler likes where under the motor mount, mines the v6 but would thing they would run both the same way.
Old Mar 20, 2011 | 01:37 PM
iamsuperbleeder's Avatar
this is with a manual trans, but the engine grounds should be in the same places
https://www.yotatech.com/forums/f116...-guide-194413/
Alexdosdall
Dec 10, 2017 05:48 PM
live4soccer7
May 11, 2016 06:52 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
