- 4 x 4 Q u e s t i o n s
- Turbo!
- Alrighty... Here is my invoice from the ol' mechanic
- 3.0 problem
- Transmission bad? Or needing rebuilt?
- transfer case oil
- Spare tire carrier..Pickup
- Overheating w/thermostat
- alternator swap(84 to 86)?
- finding exhaust leaks
- Extreme cold issues??
- What is your wheel BS? tire size and lift pls
- Squeak coming from the front?
- Pics of your rig to post as Rig of the Month
- Trans sawp or replacement
- Electric choke ?
- hard start/rough idle
- Dont know what to do next...
- 95 4R cat replacement question
- lights on - warning alarm, is this stock
- push rod help!
- 2nd gen 4runner dash in first gen
- Will Pay Top Dollar!
- CV Shaft Clearance issue
- 87 runner, poss purchase?
- 22re ground points
- tips on replaceing the heater and ac controls
- Valve/Timing Noise...Help
- noisy 3.0
- Hi-Lift placement
- installing 3.0 with tranny and tcase
- Where is the 4x4 hybrid
- longbed VS short bed measurements
- What could be my issue now. 22r timing chain
- Running light issue..
- Torn CV boot on 88 P/U
- What is the best SaS kit for 91 toyota
- 4Runner GasTank Swap
- Windshield Trim options
- can someone verify this...
- new shackles installed pics/ showin her off *lots of pics*
- Unidentified gaskets in radiator
- E-Locker trouble???
- Are fancy clutches worth it?
- check engine problem!!
- running lights/tail lights failure
- 4wd not working
- Adding power mirrors to an '86 4Runner
- Anyone ever done a body swap?
- Engine swap?
- Brake abnormality
- Custom ehhh I guess supercharger....
- 81-86 and 87-92 supra brakes and trannys
- 22RE intake bolt specs
- Where Do You Mount Your Relay
- Cheap poor mans lift kit, Questions
- Suicidal Starting Problem
- new prerunner front bumper... QUESTIONS
- 88 3.0 possible Code 11 and fuel issues
- 91 4Runner 4X4 auto trans Suspension lift question
- T-case Question
- Parts
- Heater core replacement questions
- 1994 22re Exposed
- 22RE running bad after new timing chain
- my snorkel a how do kinda thing for 104 bucks ***56K warning***
- new here just got a 1993 t100 for free
- Camshaft ID
- New member w/ heater-blower problems
- Rear Bumper
- need a good picture of a 22re
- 2nd gen Repack front wheel bearings parts req.
- New an have a Q
- New rear bumper and sliders! *56k warning*
- 22re running rough hot... help!! please
- Custom Snorkel idea
- Speedometer/Odo stopped working.
- speedo ***searched*****
- Drivetrain lift Q's
- How do I get my speedometer working?
- Replacing Thermostat on 90 4Runner
- 99 4Runner no brakes extreme cold
- question about swapability of parts from 2nd gen runner to 3rd gen pickup
- Back window on 87 Runner down, won't go up
- Rocker noise, grrrrrrr!
- Rims
- Hoop Style Light Bar
- Recomendations on LC80 lift tall tall VS short short pairs
- 22re trouble shooting
- connecting gearbox to universal joint on steering shaft
- Flywheel
- Hafta sell my beater - central ohio
- opinions on leaf springs
- mounting a 1st gen grill on a 3rd gen truck - anyone done it?
- electrical problems
- Wont turn over?
- 83 grill on 87 pickup
- Leaves Or 4-link?
- For sure???
- Body Swap from an 88 4Runner to a 87 Frame
- Rear brake shoe replacement.
- SWEET rare 2nd gen headlight covers on ebay w/ 5hrs left!!!!!!!!!!!!!!!!
- longer rear shock idea, borrowed from Land Rover
- fuel in the oil?
- How much is my 2nd gen 4runner worth?
- check engine light help no code id
- weird noise from front drivers side wheel
- Towing with stock 91 4runner
- body mount bushings
- Riding Lights (What Gives?)
- 91 4Runner question:
- 1994 4runner auto trans
- rear sag fix with no lift?
- rear shackle
- New toy! Can't wait to install
- rear wheel bearing gone or what??! video.
- Figuring that coolant leak - head or intake?
- Rear Window Problem
- 4wd not working, add bypassed
- new funny noise
- Pizza Cutters...
- need a lil help narrowing the search
- gauge cluster? !? 91 4x4...
- 95 4Runner 4dr-Need R/R qtr wheel opening molding
- Magna Fluxing
- Full off road protection ideas
- Shackle tightness
- Teh one test it didn't pass
- Got rid of that Jake Brake sound!
- 94 4runner running hot on idle
- 88' 22re Engine Problems??????
- Another 3.0 engine noise question
- Pick-up Wiring EWD
- help with 89 sr5
- electronic supercharger
- looking for a second opinion on trany problems
- 1995 starting problem
- fuel injector problems?????
- New Headlight Q's
- Near Overheating
- 3.0 V6 muffler size 2.5 or 2.25?
- 83 pu steering wheel on an 86 pu. direct fit?
- 95 pick up not running right
- Straightening a frame
- mystery anti-freeze leek.
- 89xtra cab rear seat
- Quality Brake Rotors
- 4runner roll bar, should I??
- Diehard Platinum needs minor mod to install
- does anyone actually sell an elocker already modded?
- knock sensor wire part number?
- Opportunity for a GMC donor, What all to take?
- Using 4lo with hubs unlocked
- Werid 4WD issues.....
- BJ Spacer Question
- Rubbing noise (only when cold outside)
- Terrible Gas mileage
- cold valve adjustment?
- 3.0 running too cool
- Shifter vibration
- 2nd gen alternator wiring assistance request
- 5 speed trans noise
- Engine coughs/cuts out very briefly on hwy incline
- New owner, won't start- no check engine light
- Modification laundry list! Any help is good.
- 5uz swap questions
- Cod 71
- well im bored lets see if you are too
- Driveline vibrations
- Another seafoam thread.
- Tire fitment issues!
- Engine choices!!
- check engine light! doh!
- My friend and I need help.
- New drums, now pulsates.
- 3.0 head gasket blown again
- 1990 4x4
- transfer question case again
- Need help centering steering wheel
- I'm doing a valve cover gasket replace ment.
- radiator reservoir is bubbling air
- 4runner parts
- Right hand drive conversion, anybody done one?
- 89 yota wanders bad in 4WD!
- Crushed Reed Valve, need a replacement
- a question to all running 33 x 12.5
- Windshield and trim ?s
- Gearing Advise Pleeaassee!!
- lower control arm
- First 10 emails get free decal.
- IFS CORE, IFS CLUB & SAS CLUB Decals.
- Brakes: Where can I get disc/drums/pads/shoes?
- Online parts catalog? For part#s, etc Newbie
- Preparing for mud racing... Suggestions?
- 3.0L 3VZE rebuild. Need help finding parts
- Which IFS Club decal do you like?
- 2wd flex pics...not what youd think
- Need Help Now!!!!!
- IFS / SAS Club decals
- 3vze air intake hose parts
- PS pulley help
- Difference Aussie vs Lock Right?
- Which Wheels?
- Changed front diff oil...now grinding sound
- replace dash and fuel light.
- 3vzfe acting odd
- 95 runner AT problem.
- questions on 3.0 headgasket
- need help
- 87 pickup on 84 frame
- 4runner clutch/transmission noise
- New brake lines, now soft brake pedal
- IFS differences??
- performancecenter.com?
- My Toyota is SO freakin' TOUGH......
- singed fan wires???
- large flares???
- Looking For Some Local Help For My 4Runner - Eastern PA
- Just Seafoamed...
- Rear End Grinding & clanking
- New Shocks And Fogs
- Supra AFM in 22re
- Instruction on valve adjustment 22re
- Front Mud Flaps part number needed
- Fuel Pump
- Pitman Arm Removal
- Help needed in the UK on a 3.0 Diesel 4wd problem
- Auxiliary Backup Lights
- MSD-6A Install on the 3VZE:: A How-to for the at home mechanic
- stock rims
- Coolant leak...Oring or just RTV *pic*
- 3.0 auto to 5 speed conversion
- Hit brakes, turns come on
- 4runner
- SR5 Gauge Swap problem Fuel guage reading FULL
- 89 4runner E test FAILED
- Wow!!! Lucas Oil an Sea Foam Wow!!!
- mysterious wire / cable / sensor ?? behind dash
- Door buzzer stuck
- 1990 Auto 3vze RPM Fluctuations at idle and others
- 4x4 problems
- Console Help!!!
- sas or buy one that has a solid axle?
- changing transfer case oil..
- Magnaflow Part #
- 4Runner stuck at work with issues
- '92 ADD vacuum line routing...
- IFS diff drop
- Factory wheel off-set
- Stuck Spark PLug
