E-Locker trouble???
Old Jan 26, 2008 | 09:47 PM
Datsunon40s's Avatar
E-Locker trouble???
I have read tech articles about installing the TRD E-Locker and nowhere in there does it say anything about shortening the axle shafts but I put one in an 87 rear axle and my axles are to long they bottom out 1/4 inch away from tightening up, anyone else had this problem or am I doing something wrong ?? THANKS!!
Old Jan 27, 2008 | 06:14 AM
Spinnbait's Avatar
Just a thought, but try rotating the pinion as you insert the shafts. It may be that the splines are not lined up. Good luck.
Old Jan 27, 2008 | 06:50 AM
nate V's Avatar
yeah x2 i think that the axles are the same length!!
Old Jan 27, 2008 | 06:52 AM
AxleIke's Avatar
You do not need to shorten the axle shafts at all.
Rotate the shaft as you put it in, and it should slide right in there.
Old Jan 27, 2008 | 10:32 AM
312necro213's Avatar
How much are the elockers? Worth it? Or just go with ARB air lockerS?
Old Jan 27, 2008 | 10:34 AM
jasond's Avatar
I love the e-locker in my truck. I didnt put any resistors in the wiring, used a factroy switch and some relays and never have had any trouble with it.
Old Jan 27, 2008 | 10:35 AM
1990Runner's Avatar
there is a lot of info on YT and other places about this, search on here and even google it.
Old Jan 27, 2008 | 01:54 PM
vwfastg60's Avatar
Its been answered but the shafts are the same...something is not lining up. I had a hang up on one side make sure its unlocked and if you have someone helping you they can spin the pinion just a bit to get it to go right in.
Old Jan 27, 2008 | 08:28 PM
figured it out it was the bearings were a tighter fit than I thought thanks
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
voiddweller
Oct 2, 2015 07:47 AM
Matthew Perez
Sep 28, 2015 05:43 PM
Patrick1976
Sep 15, 2015 11:33 PM
zz_denis
Sep 6, 2015 03:43 PM
