88 3.0 possible Code 11 and fuel issues
Old Jan 26, 2008 | 12:38 PM
881stGenRunner's Avatar
In the mornings when i first start up the truck, the idle is very jumpy and goes up and down. It sounds like it definatly has a knock too. When you turn the truck off, there is a strong smell of fuel towards the front passenger side of the truck. I filled it up completely, reset my mileage, and so far i have about 95 miles on it and im down to half a tank. SOmething aint right here.
I pulled the code on it and i think it is a Code 11. Im not too sure, so i am including a video of the diagnostic test.
Thanks guys.
-Brandon
Old Jan 26, 2008 | 12:44 PM
DeathCougar's Avatar
Code 11: ECU Power supply
Sounds like you have a major problem, and with a major fuel smell, not one you should be driving around on. Especially if the fuel drips down onto a hot manifold, then *poof* your truck goes up in flames.
First step is to find out where that fuel smell is coming from. My mom just had a fuel smell issue in her 95, and it turned out to be the Fuel dampner on the pass side fuel rail. And it was puking fuel, it wasn't even safe to drive. We had to trailer it to the shop.
Old Jan 26, 2008 | 12:50 PM
okay, what can i do to fix the ECU power supply? Is there a relay or what? Also it should be noted that my 4Runner has a 'Remaned ECU' that was installed by a previous owner. I did not change this at all.
Old Jan 26, 2008 | 01:07 PM
Under where it says Engine Computer Control, there is some writing, this is what it says:
100% computer tested
Tested under extreme "on-car" conditions: hot, cold, shock, vibration
Dynamomater Proven
Meets O.E. Emmisions and Perfomance Standards
It appears as though it is made by a company named ASI
Old Jan 26, 2008 | 01:10 PM
not sure about that one.
I am always weary about those non-OEM remans. I have seen nothing but problems with them.
Old Jan 26, 2008 | 01:13 PM
hmm, you reckon i should try to find another 88 3.0 auto ECU from a wrecked 4runner?
Old Jan 26, 2008 | 02:51 PM
bump ttt
Old Jan 27, 2008 | 01:35 PM
bttt.
Old Jan 27, 2008 | 01:38 PM
You could try the ECU, but often that is not the problem. I would track down that fuel smell first. The way i think, if there is not enough fuel pressure, it could be throwing the code.
Old Jan 27, 2008 | 01:40 PM
i guess i should have said that we found the fuel smell today. The foward most passenger side fuel injector was pissing everywhere. We went ahead and ordered a new one from Advance today and it shoud be here tmo.
smthwsn357
May 1, 2024 07:28 AM
Charecter1
Nov 6, 2023 10:08 AM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
Roger Borba II
Jul 9, 2015 05:05 PM
