Where Do You Mount Your Relay
Old Jan 26, 2008 | 02:49 PM
TORTIS's Avatar
for those of you running winches and driving lights, where do you mount your relays? i installed an auxiliary fuse box, and mounted it to the firewall in the engine compartment, and was wondering if i could mount the relays there as well. i am stupid when it comes to wiring and that sort of stuff, so i am trying to learn. i mounted 2 50 watt driving lights for backup lights today and the instructions said i didn't need a relay, but my 4 100 watt KC's will for sure..
Old Jan 26, 2008 | 03:27 PM
mt_goat's Avatar
I like to use relays with just about everything:
Old Jan 26, 2008 | 05:27 PM
shaeff's Avatar
^ nice setup!
Old Jan 27, 2008 | 10:12 AM
MMA_Alex's Avatar
I've got mine on the upper part of the firewall (engine side of where the cab air comes in). Works fine, just noisy because of the hallow space behind it
It works fine pretty much anywhere you wanna put it as long as its not insanely hot, or has exposure to a lot of water.
Old Jan 27, 2008 | 12:39 PM
standardbyker88's Avatar
anywhere under the hood thats fairly protected works. if you are worried about gunk or water, some have a rubber boot on the bottom, or you can just use electrical tape up the wires and around the relay to seal it. i did that for the starter and fuel relays on my ramcharger since i cut out the inner fenders.
Old Jan 27, 2008 | 01:51 PM
notanymore's Avatar
i have my relays above the driver side wheel well, right behind the airbox.
okamikai
Apr 30, 2018 10:19 PM
pplusent
Sep 2, 2015 11:56 PM
Ryall
Sep 2, 2015 06:48 AM
ghostmoney
Aug 6, 2015 08:40 AM
TDonkey
Jul 26, 2015 10:14 AM
