4wd not working
Old Jan 26, 2008 | 07:06 PM
ddc_5114's Avatar
4wd not working
92 4runner manual tranny. Recently purchased truck, 4x4 not working.
replaced add hubs w/warn manuals. Hubs lock but no power is going to the front drive axles. front driveshaft spins transfer case works no unusual noise. 4wd light does not illuminate but I can hear it clicking when i shift in and out of 4wd. Anyone know what my problem is??w/ the manual locking hubs none of the vacuums or actuator could cause this right??
Old Jan 26, 2008 | 07:27 PM
80W90's Avatar
did you verify the operation of the hubs? (locking it, and hand turning the axle?)
next to do is manually actuate the add servo
Old Jan 26, 2008 | 07:31 PM
ddc_5114's Avatar
yes I tested the hubs. Everythings a go! How do I manually actuate the add servo??
Old Jan 26, 2008 | 08:02 PM
just a 22re's Avatar
i think its a vac line on there not sure were or anything but do think its a vac line as i have a 87 hope this helps
Old Jan 26, 2008 | 08:48 PM
DeathCougar's Avatar
Since you didn't eliminate ADD, i would be looing to the ADD actuator, or the VSV's that control it.
You can run vacuum pressure to one of the two vacuum lines (cant remember which one it is) which will lock the ADd collar in permanetly.
the other way to do it is remove the actuator and jackshaft assy, and replace it with a non-add jack shaft. (or just replace the whole diff if you can find it cheap)
Old Jan 26, 2008 | 09:13 PM
ddc_5114's Avatar
thanks for the advice fellas. will try actuating the actuator 2morrow. youve been a big help!!
Old Jan 26, 2008 | 10:23 PM
RobD's Avatar
http://toyota.off-road.com/toyota/Ax...tegoryId=11290
Old Jan 27, 2008 | 05:32 PM
ddc_5114's Avatar
Fixed it ..had a bad vac line and a few misplaced lines as well..now it works like a champ...thanks for the advice and links...you guys know your stuff.
Old Jan 28, 2008 | 01:42 PM
we try man we try
ashersullivan88yota
Jan 18, 2022 05:37 PM
mskalmus
May 28, 2017 07:51 AM
Road Bull
Oct 10, 2015 04:55 PM
cyclist231
Jul 7, 2015 12:56 PM
Suprarossa
Jul 6, 2015 05:21 AM
