Squeak coming from the front?
Old Jan 28, 2008 | 02:22 PM
mr_lemons's Avatar
I have a very dry, metal on metal sound coming from the front. I assume it has to do with the front suspension compressing. I only hear it when I get out... you know, when the suspension extends. Since it's the winter and my window is up when I drive, I never here it then... but I would imagine that it is making noise then as well.
any ideas?
Old Jan 28, 2008 | 02:35 PM
EWAYota's Avatar
Is it when your flexed (as much as IFS can) or when your turning? Could be that your steering bump stops are worn (probably are anyways) or your hitting your bump stops when your suspension is in upward or downward travel. Get some greese and dab the bumpstops and see if that helps.
I have to dab some greese on the steering bumpstops every couple of months to not get metal on metal on full locked turns.
Old Jan 28, 2008 | 03:58 PM
fire5's Avatar
Push down on the corners, narrow it down. Or have someone else and get under there and look, listen.
Old Jan 28, 2008 | 04:19 PM
Jay351's Avatar
check the swaybar endlinks (if you have one) Before I junked mine, it made a hell of a racket unless I lubed it.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
shisha1999
Mar 16, 2016 12:25 PM
Sep 4, 2015 09:27 AM
