Custom Snorkel idea
Old Jan 25, 2008 | 01:08 PM
Belize Off Road Team's Avatar
Custom Snorkel idea
i am thinking of doing something like 4Hummer did, just instead of running the tubes to the roof line i will put the snorkel head just above the fender so it is in line with the side mirror. What i would like to know is what size pipe do i need to hook up to the air box? cause i am going to run rubber flex pipe from the air box to inside the fender and run a solid PVC pipe to the back of the fender and then bringing the pipe through the top of the fender and sticking a snorkel head on just above the fender. either that or maybe putting the intake i the door frame so it's hidden and out of the way and if i coverd it properly very little crap woul get in there.
Old Jan 25, 2008 | 01:24 PM
89silverpu's Avatar
I don't mean to be rude but first you're thinking of putting and exo cage (or full body protection) on your 4runner and now a snorkel, is all of this necessary for the type of wheeling you do?
Old Jan 25, 2008 | 05:43 PM
just a 22re's Avatar
i did my snorkel for free my buddys front mount intercooler didnt need all the pipes so i took them two long and one 45 angle works wonders cut a hole in the top back side of fender and put it all together and i just put the filter at the top of the pipe way up at the top of the body line easy and easy ill show pics of her and the crapy cut job of the fender when it get warmer out when i need the snorkel
Old Jan 25, 2008 | 05:58 PM
NC-B17A's Avatar
just a 22re joo gots any pics man? I would like to see the snorkle you made. I have been looking at the intercooler piping kits on Ebay for awhile with the same idea as you.
Old Jan 25, 2008 | 06:17 PM
bry-an's Avatar
if you want it to look like the hummer with the round can on top.... just go to a tractor store and get a pre filter.... run the pipes to your normal airbox with the normal filter//.... will totally make it last longer
Old Jan 25, 2008 | 06:56 PM
yeah i think i have some newer kinda ones not any up close but i can get some tomorrow of the whole thing but not on the truck as its off for the winter cause i dont have my air box anymore i ran it over when i did the air filter and was stuck with it but yeah let me upload them and ill post a few now and more tomorrow in a new thread so watch for it costom snorkle coming soon to a computer screen near you!!
Old Jan 26, 2008 | 04:38 AM
well now i'm thinking of putting it behind the cowl or stick it so you can see the intake when you open the door. some where with alot of air flow but higher than the stock height.
Old Jan 26, 2008 | 01:11 PM
Redeyejedi's Avatar
https://www.yotatech.com/forums/f116...arning-135816/
and tons of others...
a lot of good ideas on pirate too, some ghettofab 5$ getups too. all depends on your creativity and needs.
i was contemplating istalling a small blower fan for low speed use. i'm so far from that mod though so, i'll still see others' cool ideas.
post what you make!!
Old Jan 26, 2008 | 01:15 PM
well i'm really swinging towards just bringing it into theupper part of the fender by the door for now. until i get other stuff done on my Surf, cheap fast and easy mod to minorly improved performance and cool air.
Old Jan 26, 2008 | 01:18 PM
Redeyejedi's Avatar
cheap and easy use pvc and laundry ducting.
Old Jan 26, 2008 | 01:32 PM
my idea exactly!
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
priest16
15
Aug 6, 2015 07:43 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
