New an have a Q
Old Jan 25, 2008 | 02:33 PM
littlewhiterunner's Avatar
New an have a Q
Whats up guys an girls new to the site an wanted to say whats up!! I also have a Question first I have a 95 4 runner 31 inch procomp x terrrans with flowmaters an a knn cold air intake the motor an body have 117k i thought I would give ya the info first. Anyway the question is when given her gas she has this little rattle faint But I can hear it does anyone have this same issue or do you know what it could be the timing chain is new so thats out i hope. The truck runs great but I want to make sure it isnt going to be a problem later on.
Old Jan 25, 2008 | 02:35 PM
Jay351's Avatar
Which engine do you have? 22re or 3vze?
Old Jan 25, 2008 | 03:36 PM
Trustyrusty's Avatar
Since he said FlowmasterS I'm going to assume a 3.0... If not, I don't know why he would have two mufflers on a 22R... Thats just my guess... If I can't see the rattle, or hear it, I can't fix it, just turn the radio up until you can't hear it.
Old Jan 25, 2008 | 03:48 PM
notanymore's Avatar
but hes talking about a timing chain being new so i assume its a 22re. i would check the valves to make sure they are adjusted properly.
Old Jan 25, 2008 | 04:04 PM
Jay351's Avatar
Yes, but I know alot of people who think the 3vze has a timing chain. Common mistake.
But if we are indeed talking about a 22re, how long has it been since the timing chain was replaced?
Old Jan 25, 2008 | 04:09 PM
tampabayota's Avatar
whats a comming mistake?
Old Jan 25, 2008 | 04:17 PM
Jay351's Avatar
People thinking that the 3vze has a timing chain, but we all know that it has a belt.
Old Jan 25, 2008 | 04:29 PM
leebee's Avatar
hehe, jay reread your op! check for a loose heat shield, there are a few of them, open the hood and take a listen in the bay. use a long screw driver like a stethoscope to check the valve cover(s) and block. the 3vz-e is a non-interference engine that uses a timing belt, 22-re IS an interference engine using a timing chain.
good hunting and let us know what you find out.
lee
Old Jan 25, 2008 | 05:26 PM
just a 22re's Avatar
a comming mistake happens in porn i though
Old Jan 25, 2008 | 05:45 PM
Jay351's Avatar
doh! *fixed*
Old Jan 25, 2008 | 05:48 PM
sleepy970's Avatar
Might also check the cat. While back I started to hear a faint rattle when I would get on the gas and could find it coming from the engine anywhere. Started to get louder and louder and noticed my mpg going down. Found out the cat was bad replaced it all was good.
Old Jan 25, 2008 | 10:30 PM
sorry it is a 3.0 6 banger has new timing belt the motor runs good I just wanted to know if anyone has had the same thing happen to them sounds like its coming from the top of the valve area near the throttle should I put her in the shop or just turn the radio up like I said no change in the performance. Also I am new to yotas an love them but i have been told they will make all kinds of noise but just keep on running fine
Old Jan 25, 2008 | 10:31 PM
Thanks for all the replies i had 10 in 3 hours which rocks love the site anyone in maryland
