4wd not working, add bypassed
Old Jan 23, 2008 | 03:09 PM
95RunnerSR5's Avatar
Hey guys my 4wd was working great until recently when it took a second of revving to convince the ADD to lock and now it does not work at all. The transfer case and tranny work great but the ADD isn't working properly. I bypassed the switches and everything by running a single vacuum line to the locking side of the actuator and putting a cap on the un-locking side so it will stay locked. I thought this would solve my problem but it still does not work. I'm going to tear the actuator off tomorrow and clean it out in case it is clogged. Any other tips or suggestions of why it may not be working?
Thanks as always,
Kyle
Old Jan 23, 2008 | 09:27 PM
RobD's Avatar
http://www.4x4wire.com/toyota/tech/add/
Are you sure you have vacuum at the end of the hose you're using? If so, I'd almost guarantee the fork is stuck and not allowing the sleeve to move.
Old Jan 23, 2008 | 11:34 PM
80W90's Avatar
a cleaning and verifying proper operation while its out is in order.
mskalmus
May 28, 2017 07:51 AM
MMA_Alex
25
Apr 18, 2017 05:07 AM
mickyd9990
Jul 6, 2015 09:01 AM
Suprarossa
Jul 6, 2015 05:21 AM
HRDC0R19
Jul 5, 2015 06:43 PM
