need a lil help narrowing the search
Old Jan 23, 2008 | 12:28 PM
swaycleveland's Avatar
so... ive got me a noise thats buggin the ba-jesus out of me ! first i have a 93 3.0 auto runner with lock outs
the noise is a humming sound to a slight whine it happens ONLY under power and dooes NOT change with RPMs just speed it happens with and without the hubs locked and will become very faint if i put it in 4wd so yes it is less if i engage the 4warp drive
i have already done the bearings packed and seated perfectly!
CV's lok great and dont bind (once again i have lock outs and ADD)
u jionts grease well and dont move at all !
no leaks from the diff( im running mobil1 syn which is 3 mth old and full )
so anyone got any ideas???
Old Jan 23, 2008 | 01:45 PM
80W90's Avatar
its tuff to give ideas, since you covered all the basics.
93- i dont recall if the spedometer is electronic or cable driven. could be a dry noisy cable. try putting truck in nuetral, and while coasting, turn off the engine. at least it would narrow down.
if not, just turn up the radio, and it will go away.
Old Jan 23, 2008 | 02:25 PM
if i drive 60 the noise is there through it in neutral and the noise stops
Old Jan 23, 2008 | 02:30 PM
just a 22re's Avatar
rear end? maybe a bad joint?
Old Jan 23, 2008 | 02:37 PM
but it changes in when in 4wd so that means its up front
Old Jan 24, 2008 | 05:05 AM
bump
128keaton
Sep 3, 2015 05:09 PM
Jacob Aisenbrey
Sep 2, 2015 12:19 PM
-T-
Aug 31, 2015 07:26 PM
hmmhoyhoy
Aug 12, 2015 10:33 AM
smiley52
Jul 11, 2015 05:16 AM
