- 90 Toyota Sr5 Pickup Gear Problem?
- 1987 sr5 4runner idle trouble after running for a bit.....
- radiator overflow when refilling
- 4Runner RPM jumping at constant speed/gas pedal pressure
- Downey 4 runner springs on a pickup.
- 88 4Runner oil pan removal
- Front shock mounts damaged...
- Backup lights aren't working
- Troubleshoot squeek-95 4runner 4wd
- A340 questions
- Damage to 3VZE heads
- got yota back, but still doesnt run 'al dente'
- 92 4runner transmission slip
- Cracked block?
- Power Steering cover spins freely - fluid leaks out
- Need driver side drop transfer case solution for R-series transmission
- I got a seized bolt dilema! Any ideas?
- My 87 4Runner running like crap upon warm up...
- Help me identify these two wires - '95 4Runner 3VZE
- Advice on 22RE head
- Broken top rear shock mount 92 4runner
- will headers from an '85 PU 2wd fit my '90 PU 4wd?
- 94 with issues
- Electrical Problem...
- Steering parts off of ebay
- Truck Runs No power
- need some help with auto trans swap
- Code 25 air/fuel lean
- 3.0 timing chain
- transmission problems/advice?
- 91 5sp getting nasty noise from tranny
- 1st Gen 4Runner ZUK Mod DIY/How to (Lots 'o' photos!)
- 130 amp funny bonus
- Blazeland LT and Chevy 63's
- 91 3.0 starts and sputters for a few seconds
- lower control arm removal??????
- Weird snapping / knocking
- Overheating issue..weird one too
- Ac Compressor question
- Broken Connection on Starter Replacement? (Pics Included)
- 95 4 runner inside panel removal
- Condensation? Injector?
- Speedometer
- Adding second 80 amp fuse.
- HELP installing rear 4" Superlift in '93 4runner!!!
- front power window question - wont open
- headgasket info 22re?
- 92 Fuel Gauge problem, please help
- Which Doug Thorley header part number do I need?
- Another 22RE to 5VZ-FE swap (1990 4x4 pickup 5spd xtnded cab)
- Searching for 22r Dual Exhaust
- Whooo Hooo - Got through Emissions on 4th Try! :)
- help with timing chain/engine noise.
- i just cried a little inside! broken cam bolt
- solution: emergency brake light on
- 3rd member question
- What fluid to use in my t-case?
- What are these?
- Crankshaft pulley and key issues
- Intermittent high idle
- ADD Hub Assembly Question
- Fuel pump issues
- 88 3.0 efi relay???
- painting or coating wheels
- Wider Arch Help??
- Electrical problem with alternator???
- Doing a ISR mod this weekend.
- Looking for quick advice on LCA
- ISR Mod Lowered RPM?
- Pinging/Tapping sound between 1000 & 2000 rpm
- Turn signal indicator switch problem??
- Found a Downey set. A few Questions
- 87' 4Runner radio wiring help.
- do 4runner have these too?
- PTO Install??
- Found the casue of my engine knock/tap
- Temp problem
- Rod knock on newly rebuilt engine
- intake manifold modification
- Manually rolling up rear window?
- How bad is an auto transmission on a stock 22re?
- Crank pulley question
- Rod bearing question
- Radiator Issues
- Wireing Help
- 1993 4runner stuffed 33x14x15 under her
- weird misfire
- Random hoses and crap
- cranks but no start
- Swapping the bed out
- 4-runner cat-back on pickup?
- 22RE Smoking Black Smoke.. NEED HELP PLZ...
- AFM swap question
- wwhat type of lift is this????
- Replacing the heads on a 3.0, Should I replace the piston rings?
- New locker first run pics
- 22r moto build should I
- Difference between 2wd windshield and 4x4
- Keep having to turn idle up.
- '87 Pickup 22r Idle Problem
- very weird idle problem
- 1990 dies going down the road?
- 5" LIFT want to get rid of blocks
- 22RE - No Spark After Doing Timing Chain
- Broke a Ball Joint! (Pics of new BJ install will come)
- Specific rear window problem
- 22RE valve cover removal is a Pain!
- 84'-89' and "newer" frame width differences?
- Neither fuel gauage or temp guage work!
- CB Radio Idea-Want some Opinions
- 94 with the 3.0 smoking and running ruff
- Mechanic lost my flywheel cover - HELP
- Mother of all Tranny Leaks!! HELP!
- 89 4runner V6 hesitating badly
- 1988 pick up bed rust?
- Will rear brakes self-adjust individually?
- blowing gague fuse...
- EGR stuck open or closed?
- YOTAMAN85's new 4runner! and what a deal! (or steal?)
- driver side floor knocking?
- Suspension, Maintenance
- Locked up the engine today:( Suggestions?
- Bypassing deck light switch
- Nut size for the front exhaust pipe?
- 4runner rear power window question
- 90 coil fit a 93????
- Loose wheel bearings so I failed inspection
- is it my head gasket or intake gasket
- Bondo/POR-15 Question
- wore out door hinge pins
- Not your average rear window problem
- '91 Pickup to '86 4Runner rear bumper
- Clutch Slipping--22Re--In Mexico--What to do?
- Power windows super slow with car off
- Automatic trans. leak question?
- Eratic idle question???? 198922re
- engine is weak 92 3.0
- engine swap question
- custom rear links on 2nd gen 4runner
- Zinc additive in the oil???? (3VZE)
- putting 94 truck w/ 22re back together questions
- Bumper trim, what you guys think?
- who has used a napa brand clutch in their trucks having a problem
- Safari Snorkel precleaner????
- 90 4Runner V6 Engine doesn't run after power washing
- what color red
- 340H to R150F swap questions
- code 52 issue
- Another CB radio 4Runner install
- 4 Wheels is really ideal.
- 89 Paint Codes..?
- Got some BJ spacers for $60
- 86 pick up 4x4 issue
- clutch release arm spring 1988 4WD Pickup
- 1992 4runner crank bolt
- Quick questions before replacing transmission solenoids
- 150psi of oil pressure
- problems with 1987 4runner
- downy headers and starter
- Finally got around to taking pics(LOTS) of my rig
- Fan runs almost constantly on 3.0?
- Missing Part
- Ranger fiberglass bed cover, will it fit?
- 22RE intake mod question about supra afm
- panhard drop
- Power loss!!!code 52!!!
- 86 4runner missing at high rpms
- clutch/tranny issue
- How can i get rusty box bolts out?
- Sea2sky still around? --3.0 Cam Questions/recommendation
- installed front mud flaps (pics)
- 2wd vs. 4wd flywheel?
- 22R Timing Specifications? Also, distributor advance question!!
- Auto tranny fluid and filter change
- 2F into a pickup?
- Adverse affects of valve tapping question
- Egr
- Snorkel ideas
- 4WD not working
- tranny on a truck i would like to buy??
- Jumpy timing on 3.0
- 20R or 22R Clyinder head swap
- 95 4runner stalls and p/windows dont' work intermittently
- More 3.0 issues
- Custom Machining USA, 2.7 stroker opinions
- starting problem
- Hoses tangled up and ripped. Where do they go??
- Anyone used XRF chassis parts?
- Pickup Torsion Road Installation Question...
- Speedometer dances to the beat of a different drum...
- 22re running rich
- 97 tacoma cap fit 94 pickup?
- Rebuild, Replace, Or Motor Swap??
- Weber Problems
- Some questions about pinging.
- bed not full body lift questions
- Overheating questions.
- Replacing Fuel Injectors on a '95 4runner
- From A.D.D To Manual Hubs???
- fuse ID??
- Quick timing question
- Truck chugs
- Trouble codes issue 3vze
- emergency brake light stays on
- 89 truck misses @ 2000rpm+
- new 90 4runner
- !!87 4runner brakes occasionally lock. new booster??
- 91 4runner 3vze wont start
- 884runner spits and sputers
- Some odd tech questions?
- 93 4runner 4wd
- 22re died, wouldnt start, let it sit then cranks up
- Transmission Parts: Where to Buy
- 89 yota 22r Stalling at stop signs
- engine, or trany and t-case removal?
- 87 4runner issues, mostly electrical
- Runner not getting fuel.
- For the definitive answer, leaf springs? Pics
- What plug where
- vacuum diagram?
- 22R vs. V6 Motor Mounts
- 95 truck will not start
- Kinda gross under my valve cover (pic inside)
- Need help with 87 Toyota truck 22re
- shift on the fly not working
- quick questin about transmission...
- Ebay Factory electrical Wiring diagram Cheap
- Help me choose a gear ratio
- How do I "Freshen Up" my 2nd gen. Brakes?
- couple of things smog, vacuum noise
- 2nd Gen Door Auto-unlock
- O/D flashing
- 1990 toyota pickup electric doors
- before and after
- 2009 tax return = new paint and interior
- My cheap new Yota
- O2 sensor
- 3.0 Head gasket??????
- engine light
- 87 4WD truck with 22R stalling
- running board ??s
- High compression pistons and cam?
- power steering
- How To Replace Your Shackles: A Pictorial
- Radiator question
- Leak down test? and getting pistons to TDC?
- Plug on harness; ADD 4WD Sensor?
- Welded Diff
- Rear is 1/2" lower on the left side while parked
- 22re Distributer O-ring
