solution: emergency brake light on
Old Mar 19, 2010 | 03:37 PM
rustyboltz's Avatar
Thumbs up solution: emergency brake light on
For the past several months, when I release my emergency brake, the handle would not go all the way down and stay there. It would come up a notch. the other day I crawled under the truck and found that the arm that the single cable goes to to actuate the rear cables was covered with dirt and dry. I sprayed some PB blaster on it and some white lithium grease on it and worked it vigirously.
Since this, my emergency brake works like a charm!
I thought I would post this solution so maybe it could help someone.
Old Mar 19, 2010 | 03:45 PM
87AzRunner's Avatar
The light also comes on when you're low on Brake Fluid
Old Mar 19, 2010 | 03:52 PM
Jay351's Avatar
Super common for the pickup cables to get all corroded up in the back end. The 4runner has sealed cables. The pickup uses rubber boots that just disintegrate after a few years.
Mine only worked after both sections snapped and were replaced.
Old Mar 19, 2010 | 04:21 PM
pruney81's Avatar
solution: open the dash and break the bulb. J/K
ashersullivan88yota
Jan 18, 2022 05:37 PM
fountain
Dec 31, 2015 06:08 AM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
