Manually rolling up rear window?
Old Mar 18, 2010 | 09:00 AM
Irish Death's Avatar
Is it possible, if you have no power available period, to roll up the rear window?
Reason I ask is I need a part from a junkyard for my rear window. They have one there but the window is down and I cannot get to the part as its behind the window. So is there a way to roll the window up with having no access to power?
Old Mar 18, 2010 | 09:05 AM
hilandfrog's Avatar
Bring a batt, a small motorcycle bat should work and "hot wire" the window motor....
That's all I've got...
Repo
Old Mar 18, 2010 | 10:47 AM
BigBluePile's Avatar
break the window?
Old Mar 18, 2010 | 11:11 AM
Was thinking about that...
Will be running back there today to see if I can get at it...however
This is the part i need:
Its the plastic part for wires on the tailgate keyhole to roll down/up the window...anyone know if the 2nd gen ones are the same?
Old Mar 18, 2010 | 11:19 AM
Levis Pennae's Avatar
You should be able to take one of the gears out and just push the window up.
Old Mar 18, 2010 | 03:15 PM
pruney81's Avatar
I think there is a plug in the door you can take off and hot wire with a battery, pretty easy, I had to do it a few times on my old 86 that's how I know. There should be a power plug to window motor inside the door you can unplug and I believe I clipped some wires to a battery and then to the plug and it went up.
Old Mar 18, 2010 | 03:37 PM
iamsuperbleeder's Avatar
ummmm, I "think" I recall seeing a thread, note this was a long time agao, where someone fabbed up or made up some sort of hand crank, that he had protrude inside the gate, that he could actually roll the window up and down like a manual door window
a search might turn it up
not sure if that helps, but it might be an alternative way to get the window up, lol
Old Mar 18, 2010 | 03:54 PM
Tofer's Avatar
Sponsor
if you disconnect the 3 screws holding the motor to the track it will move easily..
Jun 1, 2021 01:51 PM
thefishguy77
Jul 30, 2015 10:59 AM
ItsJustD
Jul 7, 2015 07:49 AM
coryc85
Jul 6, 2015 04:07 AM
