From A.D.D To Manual Hubs???
Old Mar 11, 2010 | 08:31 PM
90toyo4runner's Avatar
Hi everybody, I have a 1990 Toyota 4runner 5spd and having problems with my 4wd. It wont engage and I took it to a tranny shop and he figured it would be the actuator on the front diff, which is a couple hundred bucks. Some friends suggested putting manual hubs to eliminate all the problems with the A.D.D. The thing is I talked to 3 people and got 3 different answers on how to change them. One person said to go to the junk yard and get stock aisan hubs of toyota and they should just bolt on and work, another person said i need hubs and a spindle conversion kit and another person said i need axles , hubs, spindle kits. So if i get some manual hubs from a toyota what do i need to do to switch from A.D.D to Manual Hubs. please help snow is here where im at,.. Thanks
Old Mar 11, 2010 | 09:12 PM
camo31_10.50's Avatar
SEARCH my young padawon....its covered alot..lol prolly like..once a week!
Old Mar 11, 2010 | 09:22 PM
Jay351's Avatar
Permantly lock the front diff by looping the vac lines.
Then go get aisin hubs from a 86-95 truck/4runner, then remove your hub flanges and bolt on the hubs.
Old Mar 11, 2010 | 09:28 PM
what do you mean loop the lines? do i have to take the actuator off and mess with the fork at all? thanks for all the info guys
Old Mar 11, 2010 | 09:32 PM
Jay351's Avatar
Well, if you can get it to lock, then you can apply vacuum and loop the vac lines. So it keeps a vacuum.
Unless the actuator is broken. Then go get a used halfshaft and replace it.
Old Mar 11, 2010 | 10:21 PM
RobD's Avatar
Everything you wanted to know, but were afraid to ask: http://www.off-road.com/trucks4x4/ar....jsp?id=399612
Bottom of the article has all the how-to on locking the actuator. It's a simple job. As was mentioned before, check wabfab's site for a set of Aisins. Remove the old flanges (very simple) and bolt the new hubs into place. Might take you 45 minutes or so.
Old Mar 11, 2010 | 11:24 PM
DeathCougar's Avatar
Installing manual hubs will NOT fix your ADD woes.
With ADD, your CV axles are always locked to the spindles via drive flanges, so there is a problem somewhere else in the system.
Old Mar 11, 2010 | 11:35 PM
vital22re's Avatar
totally a bro
have you tried checking voltage at the vacum switching valve? Does the 4wd light come on when you shift it to 4wd? You need do to some diagnoses work. Could be your vacum line to the actuator is torn.
Old Mar 12, 2010 | 12:40 AM
Corey's Avatar
Co-Founder/Administrator
If you get around to installing some manual hubs later...
https://www.yotatech.com/forums/f125/
There is a few articles in the tech article section.
Old Mar 12, 2010 | 08:24 AM
no the light doesn't come on, but the transfer case locks in when i put iti in 4wd, the guy at the tranny shop tested the vacuum and said when in 4wd it has vacuum going into the actuator but not out, so he said that the it had vacuum going to the actuator and the t-case was working so said it was the actuator
Old Mar 12, 2010 | 08:29 AM
4Crawler's Avatar
http://www.4x4wire.com/toyota/tech/add/
Old Mar 12, 2010 | 08:45 AM
So if you know its the actuator, you can fix it. Right?
This goes back to my post. You cannot fix a problem with the ADD actuator on the DIFF, by replacing the drive flanges with HUBS. They are two different systems.
Either 1. replace the actuator, 2. lock it in all the time (people have used hose clamps, but I do not recommend that) 3. replace the diff with a non-add setup and do a manual hub swap or 4. Buy a Prius
Old Mar 12, 2010 | 09:03 AM
im good on the prius.. but i found another thread and decided to go the route with locking the actuator fork in 4wd they used a hose clamp too( what do you recomend using?) and then puting manual hgubs on
carlspeed
Aug 23, 2015 02:59 PM
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
PlayAwhile
Jul 20, 2015 11:36 AM
ItsJustD
Jul 7, 2015 07:49 AM
