driver side floor knocking?
Old Mar 15, 2010 | 10:04 PM
Sly4Running's Avatar
Unhappy driver side floor knocking?
i have a 95 4Runner sr5 v6 IFS 3.slo. i recently had to replace the right lower control arm because of a in pothole. anyway after the deed was done i noticed a "knocking" in my floor panel when i make sharp turns and it never did that before! it feels like a giant bubble is popping under my feet and sometimes it'll do it between 2 and 6 times in a turn! idk what it is, i checked with the mechanic who helped and he says he cant see anything wrong but he sure feels it and doesnt know what it is... has anyone else had something like this happen? can you tell me what it is?
Old Mar 15, 2010 | 10:08 PM
thedanned's Avatar
Does it do it when you are moving and turning or sitting still and turning the wheel? Make sure you didnt leave anything loose. Swaybar maybe?
Old Mar 15, 2010 | 10:54 PM
yodafreak's Avatar
dang man , you figure it out , let me know , my 93 does the same damn thing LOL
Old Mar 15, 2010 | 11:36 PM
abecedarian's Avatar
How are the sway bar bushings?
Old Mar 16, 2010 | 04:09 AM
Stroheckeral's Avatar
x2 on the sway bar bushings
Old Mar 16, 2010 | 06:39 AM
Wrenchinjoe's Avatar
Do you have manual locking hubs? If the sway bar checks out ok, make sure the c-clip is on the cv axle and that the hub was installed correctly.
Old Mar 16, 2010 | 06:46 AM
dropzone's Avatar
Fossilized
one thing to consider is a missing body mount bushing
Old Mar 16, 2010 | 07:08 AM
it only does that while moving and turning. its completely fine while sitting. hey that's a good thought i'll check the sway bar today! i'll bbl!!!
Old Mar 16, 2010 | 07:09 AM
really?! well 20% of me is happy that SOMEONE else knows what im talking about lol? but the other 80% is still kind of concerned/mad about it all... checking it today, might be the sway bar...
Old Mar 16, 2010 | 07:13 AM
ok so bushings, sway bars and sway bar bushings, and to Wrenchinjoe, i do have manual locking hubs. everything is being checked out
Old Mar 16, 2010 | 08:56 AM
ok so the mechanic said it was either sway bar bushings or an "interruption" in my steering linkage. I BELIEVE the sound and bump were coming from the turn stoppers because they ARE getting old and they are rubbing against each other when i max out my turning. i hope some of this helped, there will be more to come and pics are on the way!
Old Mar 16, 2010 | 09:08 AM
rattlewagon's Avatar
my trun stops make noise in both my 87 and my 92, but neither of them thump, and its only when turning at full lock.
does yours have to be at full lock to make the noise/thunp?
Old Mar 16, 2010 | 10:55 AM
Jay351's Avatar
Are you talking about turning at full lock or not? If not, look at ball joints..
Old Mar 16, 2010 | 06:41 PM
"does yours have to be at full lock to make the noise/thunp?"
yes it does, at full lock.
Old Mar 16, 2010 | 06:43 PM
WAIT WAIT WAIT! im dumb! im not talking about 4 wheel drive. i'm talking about normal 2wd at full crank of the wheel! sorry im not quick today lol
Old Mar 16, 2010 | 06:49 PM
in the second pic, the arrows point out where the turn stops are supposed to meet and signify the CORRECT direction they're supposed to behave. the circled part of the picture shows that the left stop not only goes left and right but up and down on the right stop. which is BAD! and that my friends is what is causing the bump and noises.
Attached Thumbnails driver side floor knocking?-mar16_002.jpg   driver side floor knocking?-edit.jpg
Old Mar 17, 2010 | 05:51 AM
Wipe them down good and spread some multi-purpose grease on the all four of those stops. Those things can make some nasty noises when they get dry. If needed, you can get replacement stop caps at the dealer. I wipe them down and apply grease with every oil change.
Hope it was that simple
Old Mar 17, 2010 | 05:48 PM
oh ok cool! actually i just adjusted the stops on the wheels-side up half an inch and everything's hunky dory! now i just need new brakes...
thefishguy77
Jul 30, 2015 10:59 AM
CanRunner
Jul 20, 2015 01:29 PM
msane99
Jul 17, 2015 10:13 AM
razorman8669
Jul 12, 2015 12:13 PM
crashburnoveride
Jul 10, 2015 06:39 AM
