Electrical problem with alternator???
Old Mar 18, 2010 | 11:03 PM
evildiscoball's Avatar
i purchased an 86 yota and put in a new motor after the purchase. When i put in the new motor i noticed that the stock plug for the alternator was not the same for the new one on the swapped motor. Tried putting in the new alternator but the bracket wouldn't bracket in. I cut and sautered the wires to the new adapter to plug in. After i realized that the gas gauge and turn signals wouldn't work anymore. could there be anything related to it or not. i checked all fuses and also replaced the flasher for the turn signal with no luck. (the emergancy signals still work) hope this gets an answer, couldn't really get any answered from archived forums.
Old Mar 19, 2010 | 06:59 PM
myyota's Avatar
What year 22R or 22RE did you swap into your 86 toyota ?. If the plugs were diferent you should have just swapped the alternator from the original motor onto the new motor, it should have been a direct swap.
Old Mar 20, 2010 | 08:39 AM
They were the 22r, but the alternater was a different plug in and bracket into the swapped engine. the bracket didnt line up and also the plugs are different.
Old Mar 21, 2010 | 05:01 PM
weaselman's Avatar
what YEAR?
redneck17
Oct 29, 2015 09:09 PM
coryc85
Sep 9, 2015 06:24 AM
Yota.Jay
Jul 23, 2015 08:08 PM
v_man
Jul 23, 2015 04:01 PM
colinmil
Jul 6, 2015 04:03 PM
