Specific rear window problem
Old Mar 16, 2010 | 09:08 PM
Chikokishi's Avatar
I completely took the car apart trying to figure out why it wouldnt work, but i found out that when i ground the center wire from the switch in the consol, then pressed the button, it worked perfectly. So then i moved down that wire and i traced it (sort of... it goes into a bundle.. then i found another wire that goes to the lock button) to the lock button, and when i grounded a certain wire on the lock button it worked. and i messed around and around with it, and if i grounded the wires comming out of the lock switch the window would work, but no matter what i do i cant get it to work without an external ground. For now i stuffed wire into one of the wire connections, and i grounded it to the chassis. But i would like i fix the circuit
Power (?) -->-- up/down switch -->-- lock switch -->-- rear window...
but where is the *real* ground? Or do i have this wrong?
Old Mar 17, 2010 | 07:23 AM
CappyKD's Avatar
The answers can be found here.
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
Jnkml
Jul 6, 2015 01:20 PM
