Truck chugs
Old Mar 11, 2010 | 05:36 PM
TenaciousT's Avatar
Truck chugs
Background-New head gaskets, water pump, plugs on a 94 3.0 ~1.5 months ago. Everything runs well, but I've been having some difficulty starting it in the mornings and it requires a long crank.
Secondly, while driving and keeping the tach between 1500-2500, it likes to chug chug chug like a choo choo until I get my rpm's up to around 3k.
I do have a CEL on, and I've checked it as a code 25 before, cleared it, ran it, tested it again per the FSM and it doesn't come back on until much later.
I've tried to see if there are other topics like this, but I haven't been so lucky and I would appreciate some direction in fixing this.
Thanks in advance!
Old Mar 12, 2010 | 06:34 AM
vandert's Avatar
Sounds like a cold start injector issue which means it's an EGR issue which goes right along with what your saying.
If the valve is stuck open it will effect the drivability down low - below 3g's, and will effect the Cold start injector as well
Could also be as simple as a vaccum line but it's definately EGR or vaccum line improperaly hooked back up after the headgastket redone.
duckhead
170
Nov 13, 2017 06:07 AM
voiddweller
19
May 2, 2016 09:10 PM
MadMax48
Jul 3, 2015 08:26 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
