Condensation? Injector?
Old Mar 20, 2010 | 10:59 AM
LoveOldToyotas's Avatar
My ability to work on my Toyota is limited. I know just enough to get in trouble, but I am not afraid to learn as I go... This winter I let the gas get below 1/4 tank in my 87 Pickup 22re Auto. Ping, ping, ping... It started running rough, felt like it was missing.
I recalled the fact that condensation might have gotten drawn in and dry gas might help. I gave it a shot and about midway through the tank the issue went away.
Then, every so often, it would miss again, regardless of fuel level. Now its back, and its constant. Any ideas?
Thanks in advance.
Old Mar 20, 2010 | 04:25 PM
myyota's Avatar
Did you replace the fuel filter ?, if not, try doing that and see if it helps.
Old Mar 20, 2010 | 04:32 PM
24Runna's Avatar
If you replace the filter, and cant get it unscrewed, just cut the lines and use 1/4" fuel injector hose and any generic 1/4" fuel filter (under $10) So easy to do, takes me 10 minutes to replace it.
Old Mar 20, 2010 | 04:33 PM
24Runna's Avatar
Also you might want to think about doing a tune-up. Plugs wires, cap & rotor, ect. Use NGK or Denso.
Old Mar 21, 2010 | 03:33 AM
Wires, Plugs, Fuel Filter
Thanks for the replies... I replaced all those this last fall. And the fuel filter was tricky! Didn't do the cap & rotor though... So I'll check that.
Thanks.
Any experience with fuel injector cleaners, etc...?
Old Mar 21, 2010 | 05:21 AM
budro's Avatar
I had some water get into my tank last year (forgot to put the gas cap back on then it rained the next morning) STP makes a product that allows the water to blend in with the gas. My case was pretty severe and it still did the trick. Ran crappy till the watered down gas was gone but after that it was like nothing happened.
Old Mar 23, 2010 | 03:49 AM
abecedarian's Avatar
A pint of isopropyl alcohol (a.k.a. "rubbing alcohol") and fill up the tank should help get the water out of the tank.
Here's the thing: water mixes with alcohol, alcohol mixes with fuel, so adding alcohol to the fuel cause the water to pass through.
Last I saw, a bottle of "Heet" or fuel drier / water remover was like 3 dollars for a pint... and rubbing alcohol is that much for a quart or more.
coryc85
Dec 5, 2015 08:42 AM
Badlander
Oct 10, 2015 08:05 PM
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
themightykhoner
Sep 18, 2015 02:28 AM
