PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Engine...what did I do wrong!? DESPERATE
  2. 2nd gen ABS system.
  3. '86 SR5 Truck Speedo No Worky
  4. Water outlet is leaking on 3vz.
  5. Will doors off of a 87 4runner swap out with the doors on my 86 4x4 standard cab?
  6. Manual Porp valve doesnt porp enough on rear disc conversion
  7. 1994 4 runner 3.0 LOW idle after warm
  8. 91 Pickup No start No spark
  9. 2050 motor oil question ?
  10. 95 4runner 3.0 Sputtering past 1.8k RPM
  11. Turn Signal Switch
  12. Tranny Fluid in Power Steering?
  13. Straighten Out A Pillar
  14. Troubleshooting the temp gauge sender??
  15. fuse box problems
  16. Speedometer doesn't work but Odometer does
  17. 22re Cylinder Walls
  18. Coolant hose part number
  19. Oil Leak
  20. Help buying a 93
  21. 88 4Runner diffs
  22. code 25
  23. Heater core bypass
  24. 4runner shakes violently
  25. Finally found THE ONE (1987 SR5 4Runner) w/ pics
  26. been a while---new 1988
  27. 87 4x4 Pickup throwing codes 6 12 and need help deciphering
  28. Switching 22RE from a '91 to an '87
  29. 95 4Runner 3.0 CRANK NO START...
  30. A340H Txfr Case Rear Output shaft Vibration
  31. 1990 4runner runs like crap when warm (V6 3VZ-E Auto)
  32. 93 4Runner EFI Blowing when shifting to reverse???
  33. 95 4runner, needs engine, what will work as a swap
  34. Please help with some trouble shooting- 1993 4runner 3VZE automatic
  35. Bad Fuel economy after accident
  36. High idle 87 4Runner 22RE 4WD
  37. 1989 w56C w/forward shift to w56B w/topshift
  38. Timing issue
  39. Is this an OEM Toyota flywheel? (pics attached)
  40. window seal / dust sweep replacement
  41. Missing tailgate seal?
  42. What is pinston gap clearance for 93 toyota 22re?
  43. Automatic Transmission
  44. Motor mounts: Are they a PIA to replace & is OEM needed?
  45. Things that bother me when shifting and where to start troubleshooting.
  46. Need help identifying a wire
  47. 3VZE install with trans in vehicle
  48. 93 4x4 Reg Cab - Stock wheels, stock graphics? (pic heavy)
  49. 1986 4Runner - Replacement of Window Regulator with Vented Window
  50. Engnbldr isn't selling parts HELP
  51. Replace rear main seal while flywheel is out?
  52. Xtra cab bench upgrades
  53. Grinding noise after replacing timing chain
  54. Would sliders for a '95 Tacoma fit a '92 pickup?
  55. Starter wires
  56. IACV idle issues
  57. 22re O ring size wanted for coolant line under intake. (Not part# or where to buy)
  58. Components needed for lifting front end ifs
  59. rebuilt 91 front dif
  60. Will I run into issues to a ‘93 vol2 and a 94 vol1 be ok for a ‘88?
  61. Rattle-clunk on bumps and braking
  62. Starting problem
  63. New Head, New Head Gasket-Still Dumping Coolant and White Smoke. HELP!!
  64. 3vze persistant code 41
  65. How to loosen drive belt on 3.0 to remove PS pump?
  66. 89-95 door rattle
  67. 3vze troubleshooting
  68. Clutch recommendations for a stock 92 4WD 22RE
  69. Lower idle when headlings turned on
  70. What are this 2 bottons for?
  71. 1994 Toyota Pickup Vibration
  72. 22RE alternator belt installation
  73. Starter wont crank after transmission install
  74. Need purchase advice on a strange 'Yota...
  75. How I Smogged my P/U (22R, 2WD, Carbureted) High NOX
  76. 1994 22re Charging and EGR Issue
  77. My 1990 Jalopy needs help
  78. ISO 1988 toyota shifter Bezel
  79. 1994 Pickup 22RE - Ignition only clicks when car is cold.
  80. Fuel line bracket/flange repair (top of tank)
  81. Fuel Filter Recommendation
  82. 93 4runner 3.0l VZE Manual
  83. Electrical problem
  84. Gen 2 Loud exhaust tick? Maybe leaking exhaust manifold?
  85. Auto 4x4 transmission slips on take-off
  86. 3rd Gen Suspension on 2nd Gen 4Runner
  87. 1993 hilux surf 1kzte lumpy idle
  88. coolant issue
  89. Help with Soft Brake pedal
  90. Tranny recs? (manual)
  91. Brake bleeder size(s) for a 92 pickup 4WD?
  92. distributer cap boot
  93. 3VZE Where does this metal piece go?
  94. 1993 4runner ecu
  95. Crankshaft turning
  96. 34 ADM troubles PLEASE HELP!!!!!
  97. Looking for truck topper for 1989 Toyota 4x4. Help! :)
  98. HARD STARTING 1994 22re Pickup
  99. switching to 4-port injectors
  100. Very rough idle after warm up.
  101. Rear heater/cooling pipe/tube?
  102. function of 'gas filter'??
  103. loses all engine power
  104. lose all enough power
  105. Looking for this specific section of window seal
  106. Groaning Sound From Front When Going Forward with Hubs Locked
  107. 94 Pickup Engine Swap - Electrical Issues
  108. Electrical Issues
  109. suspension refresh
  110. Convert Tailgate to Storage
  111. What's the easiest way to eliminate a saggy rear end?
  112. Fuel pump stops working
  113. Park/Neutral Position Switch Location during startup for automatic 3.0 a340h 1993
  114. 22RE stuck coolant engine drain plug
  115. High Flow Cats
  116. sporadic rattle from driver side front end
  117. H4 upgrade?
  118. How many slipnes???
  119. Cold Start injector intermittent, HELP!
  120. Idle Surging After Cleaning Throttle Body
  121. Exhaust? Help!
  122. Do 2nd Gen Lower Control Arms exist?
  123. transmission
  124. '92 4Runner SR5: Help/Advice w/ Build
  125. Brake Upgrade project
  126. ARB front bar install question
  127. Can a bad key switch throw a code 6?
  128. more help finding parts
  129. Vibration
  130. *FREE Yotatech Decals*
  131. Pitted 22re block and head
  132. 22r weird air noise
  133. Help finding spare parts
  134. under oil cap 1990 22re ?
  135. 95 4runner ADD Relay removal??
  136. Automatic Gear Shift Indicator
  137. Clutch/tranny/transfer case HELP
  138. '91 3VZE Valve Clearance Question
  139. A340H 4x4 auto transmission electronic question
  140. First Gen 4Runner Vacuum Line Help
  141. Wheel opening molding
  142. First Generation Runner Featured In Movie!
  143. Truck/4runner: difference betwen 1987 and 1988 models
  144. 92 22re pickup need help
  145. 95 pickup axle swap
  146. High Idle Rough Shifting
  147. 1988 22RE No hot start
  148. Why No Serial Number
  149. What oil to use if 3.0 is only running on 5 cylinders
  150. ABS vs Non ABS Wheel Bearing job?
  151. 2nd gen 22re into a 3rd gen pickup truck
  152. My 92 2WD when I remove the key the blower motor stays on
  153. Timing chain and chain dampers (guides) replacement - When?
  154. 3" lift: Aftermarket Sway bar & rear control arms needed?
  155. Find old truck
  156. Transmission Fluid
  157. Cheap and Effective Pickup Rear Window Latch Replacement
  158. How Circuit Opening Relay Works - 22R-Eliable
  159. 1995 Pickup / Isuzu 4JB1-TC 2.8TD Conversion
  160. 1990 runner back window problems
  161. Automatic console
  162. Water bypass 3VZE headgasket install
  163. 95 3.0 4Runner running rough
  164. 22RE Not Getting Fuel
  165. Rear tail gate window regulator assembly
  166. 22re Can't Turn Crank Shaft
  167. 3vze odd hard start (VIDEO)
  168. 92 3vze not starting. Electrical issues. Please help!
  169. 93 PU 22RE won't start cold
  170. How to test the Timing Belt on 230 K miles 1990 Toyota 4Runner
  171. Throttle/Kickdown linkages HELP
  172. Manual tranny fill level?
  173. 22re pcv grommit
  174. Rear slider window for 95 extra cab
  175. 1987 Toyoya Sunrader (22RE) possible fuel pump issue?
  176. im looking to buy brass bushing for a 1988 toyota ifs v6 5 speed 4x4
  177. Headlight Replacement Question
  178. Fuel system problems!!!
  179. cold starting issue 92 toyota pickup v6 220k km
  180. 1989 4runner Tranny Issue
  181. 95 4Runner Engine Oil Leak at rear of right head
  182. control arm
  183. Starting Problem
  184. ADD delete info
  185. 1st Gen 4Runner Gas Door Strike
  186. need 92 4runner V6 help
  187. brake boosters
  188. trans pump removal
  189. rebuilt 22r dies after getting to operating temp
  190. speedo issue
  191. toyota pickup excessive oil consumption
  192. High Beams = No Lights
  193. bellhousing
  194. EGR is open, but engine does not hesitate or stall at idle speed.
  195. Timing Chain Woes
  196. Where to buy orange vacuum check valve?
  197. ignition key cylinder doorlock set
  198. starts but not charging, no power to dash or exterior lights
  199. FJ Mirror Mod HELP!!!
  200. Cracked Block?
  201. 1qt oil in a 5hr drive at 65 mph
  202. Leaky 5 speed
  203. 22re freeze plug heater
  204. Best Method to Clean the Block Deck
  205. 4wd help!!
  206. Wheel opening molding
  207. help finding spare parts
  208. Help finding spare parts
  209. 91 Pickup--Front main seal leak/TC cover leak
  210. 1994 4Runner Check Engine Light
  211. Oil gauge issue
  212. 1989 22RE Check Engine Light
  213. Heater
  214. 89 4Runner overdrive issues
  215. rear window interlocks
  216. bumper color
  217. Toyota full floating RV axle with FJ80 parts.
  218. Bull bar for a 3rd gen
  219. cheap DD turned rest
  220. Request for guidance exploding of the top of radiator on landcruiser 80 series 1Hd
  221. 22re fuel filter banjo size
  222. 1993 22RE oil
  223. water temp/vacume sensor 3vz
  224. Different style rear wipers for 1st Gen?
  225. Headlights
  226. 1990 4Runner Tires (p or lt)
  227. Really rough idle and code 27 on a 3.0
  228. metal backed chain guide slot
  229. Warn winch cover
  230. 4WD only engages when in gear
  231. 3VZE head swap question
  232. No "constant" power to certain items
  233. 4runner rear tailgate interior panel mounting clips
  234. 94 22re backfire under deaccel
  235. Truck starts but afternoon it warms up and turned off it doesn't want to start up
  236. Anyone tried one of these YJ/TJ rear bumpers on a first gen 4runner?
  237. R151+RF1A questions
  238. '89– '95 Inner & Outer Rocker Panel Rust Repair Parts
  239. Fan pulley bracket delete
  240. Steering wheel horn not working (but works off the battery& have power at connector!)
  241. A340H Transmission Electronics Question
  242. No power to fuel pump
  243. Shock extenders needed???
  244. 65MPH 3rd gear 22r 4WD
  245. Addicted Offroad tube bumpers
  246. 1995 Toyota Tacoma 3.4L Extended Cab
  247. 1995 Toyota Tacoma 3.4L starting issues
  248. Windshield trim removal
  249. Tapping noise
  250. Headlight hel
