65MPH 3rd gear 22r 4WD
Old Dec 23, 2017 | 07:52 PM
Yoda426's Avatar
Hey guys I’m new here and I have a couple questions.
i have an 87 4WD with 32/11.50/r15.
I normally will go up hills in 3rd gear at 65-70 MPH.
only for 5-15 minuets at a time,
no tachometer and engine seems to be running high rpms.
I run synthetic royal purple engine oil and k&n filters all the time
havent had any issues with my engine yet it has 135,000 miles no engine work done besides I replaced the oil pump seal and front main crank seal.
just wanting to know if you guys do this speed with this type of engine often and have had any negative effects.
Old Dec 24, 2017 | 02:50 AM
wyoming9's Avatar
Red face
My 22re engines might see a speed like that going down hill with a 50 mph tail wind
then I can turn the engine over with my hand on the crank pulley
Then all hills are not created equal
So many different things play into this equation
Old Dec 24, 2017 | 11:51 PM
gsp4life's Avatar
Gearing will also change what this means. Do you know if the PO regeared it? 32" tires fall into that grey area where half the people are dying to lower the gearing and the other half thinks it's ok. I decreased my tire size which has the same effect as lower gears (I went from 31's to 29's).
If you have stock 4.10 gears in the diffs, you're right around 4200 rpm at 70 mph. That's no problem for a healthy engine with good maintenance. 22re redline is 5750 rpm, and the owner's manual recommends shifting between 2000-4000 rpm.
I've revved to 5000 rpm in 2nd gear (49 mph with my gears and tires), with no ill-effects, just pulls hard and sounds real loud.
Old Dec 25, 2017 | 01:11 AM
RAD4Runner's Avatar
Read your your user's manual. It lists max allowable speed for each gear. Then convert that to what what is equivalent speedometer reading knowing your new size tires.
Also, like ^^ you need to check if P.O. re-geared.
LSUMatt1514
135
Dec 18, 2007 09:07 PM
95ToyotaPU007
Oct 16, 2007 05:32 PM
just a 22re
Mar 18, 2007 02:01 PM
Roadtripr
11
Feb 2, 2006 09:49 AM
BOSTON4RUNNER
10
Sep 7, 2005 07:04 PM
