ignition key cylinder doorlock set
Old Jan 5, 2018 | 01:40 PM
AngelMex's Avatar
Does anybody knows where can I but a ignition key cylinder and doorlock set?, so I won't need a key to open the truck and anotherone to start the truck.
Old Jan 5, 2018 | 02:34 PM
wyoming9's Avatar
Red face
I would just take what I had to my Lock Smith and say rebuild this or rekey the odd ball to the rest
You might find someone parting a truck out then deal with worn out cylinders
Old Jan 5, 2018 | 02:46 PM
AngelMex's Avatar
thanks
Old Jan 5, 2018 | 02:50 PM
scope103's Avatar
For the set, it's 69005-35130 About $250.00 from a dealer. https://parts.lakelandtoyota.com/p/T...005-35130.html
If you think your cylinders are in generally good shape, having your odd one re-keyed to match the others is probably the most cost-efficient solution. But, like everything else, they wear out. Rekeying a loose cylinder is worse than leaving the truck unlocked.
Old Jan 7, 2018 | 02:28 PM
wyoming9's Avatar
Red face
For the most the wear parts in lock cylinders are replaced when it is re keyed .
Have you ever watched it done ??
Old Jan 8, 2018 | 05:42 AM
AngelMex's Avatar
No, I will have to ask aaround to se if someone down here in mexico can do the re-keyed
wilbertd
Jan 29, 2015 10:55 AM
txrider
Dec 8, 2009 10:02 AM
Lava
Mar 28, 2008 06:45 PM
MSH1
Jul 14, 2005 09:37 AM
