rebuilt 22r dies after getting to operating temp
Truck info: 1985 newer block is rebuilt. bought as a parts truck.
Engine starts and runs perfect till it gets to operating temp then it idles down and dies. Almost like something is getting tight. will crank over but very slowly.
Ive swapped carbs and intakes. my only thought was maybe who ever did the machine work did it to tight? as everything expands it gets a little friction and pulls the motor down enough to kill it?
When hot, pull the plugs and try turning the engine by hand. See if it truly is tight.
is there still spark after it stalls?
is the temp sensor measuring correctly when hot? I've had one fail that was still within the range of possibilities but would lead the ECU to
think it was about -20*F outside when it was around 65* causing the car to stall.
kaylee34
14
06-16-2018 07:57 PM
cordoch
01-08-2018 03:19 PM
Ralls
12-20-2017 05:53 AM
