92 3vze not starting. Electrical issues. Please help!
Old Jan 14, 2018 | 11:23 AM
Knix47's Avatar
So I just installed my newly rebuilt 3.0. Ignition didn't turn the starter so I bypassed it with a switch. Starter turns but it's not starting. I am getting fuel and the injectors are pulsing. I tried to test the ignition signal wires and they don't test in spec when performing this test. I'm getting like 6.5 ohms from the ground to all of the signal wires.
https://www.yotatech.com/forums/f116/no-spark-91-v6-221027/
The igniter pack is getting 12 volts to both wires.
Im not sure where to go from here. Any help would be greatly appreciated!
Old Jan 14, 2018 | 12:50 PM
scope103's Avatar
Do you have spark? Use the inductive pickup on your timing light on each plug wire; if the light flashes, you have spark.
My igniter https://www.yotatech.com/forums/f116...gniter-287857/ has five wires (plus the ground). Which "both" wires on yours have 12v? (If you have a bad ignition switch, which you do, that can cause a whole host or problems.)
Have you done the FSM tests on the distributor?
solidaxle85
Mar 22, 2014 02:40 PM
jeetS
Jul 29, 2012 11:13 PM
4runr1990
Jul 19, 2012 08:14 AM
ncgamedog
3.4 Swaps
May 2, 2009 03:16 PM
Eskimo Runner
Apr 22, 2008 05:44 PM
