1990 runner back window problems
Old Jan 15, 2018 | 07:25 PM
Ducas21's Avatar
The back window will not roll down with the key and hit and miss with the switch. I don’t know if it will roll up with the key. I’m not hearing anything. Any ideas? I need access to the gate for the cooler all day for work.
Old Jan 15, 2018 | 07:48 PM
vince.stanton's Avatar
Try moving your back wiper to its resting position. This was the trick on mine, old wiper arm and it drooped down and didn't seat properly.
Old Jan 15, 2018 | 08:14 PM
Ducas21's Avatar
Just tried that. Wiper was in the correct Position. I am hearing a clicking noise now. I tried it with the spare tire in and out of Position
Old Jan 15, 2018 | 08:21 PM
Might be the gear on your window motor slipping. Somebody else here could chime in more accurately. Tire position shouldn't matter.
Ducas21's Avatar
I didn’t even know the key would move it till I saw something online. I thought the switch inside by the shifter was bad. I was going to wire a toggle in to see if that fixed it. I have a few weeks till I will make the switch from the 1 ton to this as a daily so I have a little bit of time
Old Jan 15, 2018 | 08:35 PM
https://www.yotatech.com/forums/f120...runner-259158/
Old Jan 15, 2018 | 08:41 PM
Ducas21's Avatar
Thank you.
Old Jan 15, 2018 | 10:37 PM
RAD4Runner's Avatar
Originally Posted by Ducas21
The back window will not roll down with the key ...
...I don’t know if it will roll up with the key....
I didn’t even know the key would move it till I saw something online....
??? A problem well-stated is almost solved.
Will not roll down with a key?
You don't know if it rolls down with the key?
You found out it should roll down with the key?
So did you try rolling down with the key?
How about with the switch?
Exactly what and where is the clicking you hear?
Do you hear it when trying to roll up or roll down with the console switch?
Do you hear it when trying to roll up or roll down with the tailgate key switch?
Why not describe exactly what you observe currently in one post?
Did you DISCONNECT THE connector to the wiper assembly to absolutely, positively be sure that the wiper retract switch is not preventing it from rolling up/down?
Old Jan 16, 2018 | 07:59 AM
Co_94_PU's Avatar
One common failure is the latch switch, try pressing in on the left upper corner of the gate when you turn the key or have a helper do it while using the cabin switch.
Another is the wiper park switch, make sure it's fully retracted and off the glass. You can unplug it to rule it out completely.
Another is related to the first, people slamming the gate, can shake the ground wire loose.
Another is wire damage from collision or other abuse where the harness runs thru the rear corner section into the rear quarter panel.
​​​​​​you are going to need a multimeter, some basic tools, and wiring diagram would be a good idea also.
Test the switch(es), then clean or repair them if they fail. You can jumper over them to test the rest of the system if they fail, to verify the rest of the system.
Old Jan 16, 2018 | 08:27 AM
Ducas21's Avatar
Just wondering if you read all of it? Not just the first sentence. I can not roll up a window that is already up. The only noise I hear is in the gate when I turn the key both directions I am hard of hearing and can not hear anything when I use the switch up front. If I hear clicking probably means yes I did try it with the key. Considering I said I did in the post past the first sentence. I also said the switch is hit or miss on working. Once again passed the first sentence. Not trying to be rude bud but almost everything you asked was already answered. I forgot to add thank you for the wiper idea. I will try after work.
Old Jan 16, 2018 | 08:29 AM
Ducas21's Avatar
Thank you Co_94_PU. I will try that.
Old Jan 16, 2018 | 08:39 AM
Co_94_PU's Avatar
He is actually asking you to preform some additional testing.
Listen for the relay activation inside the cab, this indicates a problem inside the gate.
Roll it down at one location then try to roll it up at the other.
"You need to put us in front of it as best you can describe." We can't see, hear, or smell your vehicle from here.
Old Jan 16, 2018 | 12:41 PM
Ducas21's Avatar
I can hear something in the rear while I am messing with the switch up front. I disconnected the wiper as well.
Old Jan 16, 2018 | 12:54 PM
Ducas21's Avatar
It is only clicking when i push up. I noticed that with the key it only clicks in one direction as well. I went ahead and cut the wires and crossed them. I push up and the window goes down now no problem at all. So now I have to figure out why or what is causing it to only work one direction.
Old Jan 16, 2018 | 01:03 PM
RAD4Runner's Avatar
We're getting somewhere....
Clicking in the rear in tailgate, or in the rear passenger area? Rear Window Control relay in first-gen is behind the driver near the driver seatbelt mechanism. Not sure about your generation.
Most likely the problem is interlocks like Co mentions above. You've already ruled out the wiper so that's great!
IF I can or someone can find the schematic, and if anyone knows location of relay module (sorry I have a 1986), we can eliminate doubts or prove bad safety interlock by disconnecting each from the inputs on the control relay module.
If you could access the motor, you can eliminate doubts about it by connecting directly to 12V.
Old Jan 16, 2018 | 01:08 PM
Ducas21's Avatar
The crossed wires and two other things with harnesses
Old Jan 16, 2018 | 01:09 PM
Ducas21's Avatar
With the key I am hearing a click in there
Old Jan 16, 2018 | 01:18 PM
RAD4Runner's Avatar
OK.... Rear Window Control Relay is in there, and it is responding to the switches. However:
1) Something is keeping power from getting to the motor, or
2) Wiring to motor is broken (but it runs one way correct?)
So most likely, it's an interlock problem. Most often, when an interlock senses an unsafe condition, it will send ground to the control module input. Need to find where each inputs into the control module and disconnect them one at time.
Might as well open up that panel to make it easy to inspect / probe / test, etc. Leave it off until we finish troubleshooting.
I know, I hate hidden fasteners, too. Fortunately, they're easier to get rid off on the firs-gens
Attached Thumbnails 1990 runner back window problems-screen-shot-2018-01-16-2.15.45-pm.png
Old Jan 16, 2018 | 01:20 PM
Ducas21's Avatar
I’m guessing this is probably my problem?
Old Jan 16, 2018 | 01:27 PM
Ducas21's Avatar
The relay is working. Makes me think that it’s something small and easy I’m missing here. It clicks both ways. The motor only try’s to move one way. I found 4 other 4runners at the local yard. I can always go there and see if one has the relay tomorrow. I need a front switch anyways. It only click going up on that
